איך להציג "מחבר" בצד ימין של שם המשתמש
סיכום מבוסס בינה מלאכותית
The discussion is about displaying the word “author” on the right side of a username for the topic creator. neo is seeking help with this customization, providing examples of the desired outcome. Don shares a solution, linking to a previous discussion on the topic, which neo successfully implements. However, neo encounters an issue with the “author” badge being hidden after other repliers on desktop. Don explains that this issue is related to the use of filtered replies and provides an updated solution, also noting that the issue doesn’t occur on mobile because embedded replies aren’t enabled by default on mobile devices.
Hi,
I’d like the Topic author to be displayed with a title (Attributes?) “author” on the right side of the username.
If the topic author has replied a post, then we can see the word “author” would be displayed at the right side.
Here is what it looks like:
or
Can anybody tell me how to do it?
Thanks a lot! :heart:
here is some thinking I’ve made, I don’t know how to work it out.
if someone = topic creator in a topic
then display “author” at the right side of the username
otherwise, display nothing
hier is some code what I got last time for displaying the post number, I think it could be similar to this one.
a.post-date span {
margin-right: 1em;
a.post-date:after {
content: attr(data-post-number)“post”;
Hello @neo,
I made this kind of author badge before… You can see here :arrow_down: I hope it helps :slightly_smiling_face:
Thank you so much! :heart: :heart: :heart: This is really what i’m expecting for!
here is my customization based on your code.
Selection_813
And i realize that “author” would be hidden after the other repliers on desktop, in my case, it looks like this:
// Hide from embedded posts
.topic-owner article .row .embedded-posts .topic-body .topic-meta-data .names::after {
content: “”;
border: none;
padding: none;
but it doesn’t been needed on mobile, why is that? :face_with_raised_eyebrow:
Glad you like it :heart::slightly_smiling_face:
If you use the new filtered replies (what meta use too) on your Discourse then you don’t need to use the
// Hide from embedded posts line
Only use these lines :arrow_down:
Because the embedded replies function wasn’t on mobile by default. :slightly_smiling_face:
