How to do Fixed width of discourse theme, No mobile view? [paid]
Disabling Discourse Theme Responsiveness for Fixed Width
veer is seeking to disable the responsiveness of their Discourse theme to increase AdSense CPC, which is lower on mobile devices. They want to fix the site width and display the desktop view on all devices.
jidetheblogger suggests setting responsive AdSense ads to display a specific size for any device width, but veer clarifies that they want to disable the theme’s responsiveness, not just the ads.
joffreyjaffeux provides a simple fix by adding CSS to set a minimum width for the site:
.wrap {
    min-width: 960px;
However, this causes issues with zooming out on mobile devices. joffreyjaffeux resolves this by adding a meta tag to allow user scaling:
<meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=10.0; user-scalable=1;" />
veer confirms that this solution works perfectly, disabling the theme’s responsiveness and allowing for a fixed width on all devices.
Problem is we use adsense for long time to finance our work. After moving to discourse The CPC and click rate is almost 5 times less. In old site we have a single theme which always opens a Desktop view, eigther in mobile or in Latop, thus gives High CPC. This discourse theme is responsive, i need to use here Responsive ad, how can i do the fixed Desktop view and width for every device ? Disable the theme responsiveness.
  • Computer view CPC is much higher than mobile ads.
  • Mobile view should be disabled and responsiveness too.
1개의 좋아요
You can set your responsive adsense ad to display any size for any device width. eg, you can force it to display 330x250 ad above fold on mobile.
1개의 좋아요
@jidetheblogger Your article is about blogs, how did you do this in your Discourse? i.e.
<style>
.OBResponsiveTop { width: 300px; height: 250px; }
@media(min-width: 500px) { .OBResponsiveTop { width: 468px; height: 60px; } }
@media(min-width: 800px) { .OBResponsiveTop { width: 728px; height: 90px; } }
</style>
<script async src="//pagead2.googlesyndication.com/pagead/js/adsbygoogle.js"></script>
<div style='display:block;text-align: center'>
<!-- OBResponsiveTop -->
<ins class="adsbygoogle OBResponsiveTop"
     style="display:inline-block"
     data-ad-client="ca-pub-XXXXXXX11XXX9"
     data-ad-slot="7XXXXX1"></ins>
<script>
(adsbygoogle = window.adsbygoogle || []).push({});
</script>
</div>
I want to disable the Total theme responsiveness of the discourse website. Not the adsense.
Check these two sites of wordpress with same theme where i disables the responsiveness.
usbar1.com - Not responsive and looks same on mobile or desktop.
collegeuniversitydb.com - Responsive which looks difeerent on mobile and desktop.
How can i do the same in Discourse. Fix the site width and disable responsiveness of the whole website.
Hi @veer,
I’m not sure I understand your requirement, but maybe this simple fix would be enough for you:
For reference and copy/paste, the css used:
.wrap {
    min-width: 960px;
4개의 좋아요
Joffrey That really helped me, But the problem now is, I cab not zoom out from the page in mobiles. How to fix that ?
Put this in Customize > Themes > Common > </head>, that should do it:
3개의 좋아요
Thanks that worked perfectly.
1개의 좋아요
