How to do multiple values properly in decorate widget javascript?
I feel silly even asking this, but I’ve tried every variation I know of and my javascript is not strong… Anyhow, I’m trying to add multiple menu items to the hamburger menu via the api.decorateWidget function.
I’ve tried this:
 <script type="text/discourse-plugin" version="0.4">
      api.decorateWidget('hamburger-menu:generalLinks', () => {
        return [{ href: 'https://yinyanghouse.com/', rawLabel: 'Our Blog' }, { href: 'https://store.yinyanghouse.com', rawLabel: 'Our Store'}];
    </script>
But that doesn’t show up – doing it like this does work:
    return { href: 'https://yinyanghouse.com/', rawLabel: 'Our Blog' };
    return { href: 'https://store.yinyanghouse.com/', rawLabel: 'Our Store' };
</script>
But it seems like there should be a way to put those into an array and return that?
You’re right, this is actually somewhat confusing. I’ve fixed it in this commit:
https://github.com/discourse/discourse/commit/bc2c6b0918c10467d40aa690919917d9090c7b84
So if you are running the latest version of Discourse you can now use an array. If not, your solution if calling decorateWidget twice will work.
Awesome! Thanks for the quick fix!
