Hello,
I am a member of wordpress and I find that the development is zero! So I would like to export my 2,500 registered Discourse.
I would like to know how?
There is no good way to do this at the moment, but it has been asked for a few times. The solution would be to create a WordPress import script that works in the same way as the existing Discourse import scripts.
Yes but how ? Can help me? I am new here !
It would need to be done by someone who knows about Discourse development. I will look at it and see if it is something I can easily do.
Thank you so much ! ![]()
Also did you checked our WP Discourse plugin? Which can be used as SSO login provider.
No, I do not want to develop wordpress anymore!
Are your current WP users in bbPress? There is an importer for that:
I do not use bbpress ! I use
anspress.io
What interests me is the users of my site!
If you just want to import users you can install bbPress plugin and proceed the migration above. I hope it will work for you.
I misunderstood install ubuntu? Can not do via filezilla?
No. You need a Discourse development environment and to run a ruby script to read the users from the database and create users in Discourse.
To be clear, you want just users and don’t care about your question-and-answer data?
Do you have a budget, or do you want to do this yourself?
Do you care about passwords?
