DScryber
(David Scryber)
February 3, 2023, 4:11pm
1
Community managers,
How do you use Discourse to uncover and list your community forums’ most commonly asked questions? It seems that top keywords or searches might help, but is there a way to find (or build) lists of questions that are similar?
Thanks!
Tris20
(Tristan)
February 15, 2023, 11:02am
Have you tried using an FAQ Tag? You can restrict the Tag so only chosen users such as moderators can apply the tag.
Now that tag support is a core feature of Discourse instead of being a separate plugin, we’ve added some new features around tagging. In this How-To I’ll go through setting up a tag schema like Car Talk uses.
We’ll want to achieve these things:
Tags for car makes and car models.
Only allow the car make and model tags to be used in certain categories.
Car model tags can only be chosen if the matching car make tag is used.
Prerequisites
First, we need to enable tags in the settings:
[tag1]
