Come generare post sulla pagina Facebook per nuovi post di Discourse
If you’re still sharing your Discourse posts on a Facebook page manually, we know how tedious this process can be, especially if you have multiple posts in Discourse that you want to share on social media. Integromat provides a solution to this problem by watching for new Discourse posts, retrieving them, and then sharing them on a selected Facebook page.
:arrow_forward: The best part? It’s fully automated! :robot:
There’s even more you can do with the Discourse app when you connect it to a variety of other apps using Integromat. For example, you can automatically create a post, topic, or private message, update or delete topics and posts, and more. Integromat has everything you need to create fully automated workflows with zero coding required.
  • Your scenario watches for new Discourse posts using the Discourse > Watch posts module
  • It then posts the topic, link title, and link as a message to a selected Facebook group using the Facebook groups > Create a post module
  • Schedule the posts to appear when you want them to
:star: Features
  • Retrieves post details when a new post is created
  • Retrieves a list of the latest posts across topics
  • Updates an existing post
  • Deletes an existing post
  • Retrieves topic details when a new topic is created
  • Retrieves a list of topics
  • Allows you to updates an existing topic’s title or/and category
  • Deletes an existing topic
  • Retrieves message details when a new private message is received
  • Retrieves private messages in your account
  • Creates a post, topic or private message
  • Allows you to perform a custom API call
:arrow_right: Connecting Discourse to Integromat
To start, you will need to sign up for an Integromat account, and then make a connection with your Discourse account. Once you register and log in, follow this step-by-step guide .
To start creating a scenario (scenarios are Integromat-speak for integrations), you’ll enter the visual scenario builder. Start by choosing the Discourse action you want, and you’ll then be asked to create a connection. To connect your Discourse account to Integromat, you’ll need to obtain the API Key, and insert it in the Integromat Create a connection dialog.
Happy Automating! :robot:
LINKS
:link: https://www.integromat.com/en/integration/5000-share-new-discourse-posts-on-a-facebook-page?utm_medium=partner&utm_source=discourse-meta&utm_campaign=how-to-generate-facebook-page-posts-for-new-discourse-posts-app-partner-community&utm_keyword=use%20case%20article%202%20-%20template
:link: https://www.integromat.com/en/integrations/discourse?utm_medium=partner&utm_source=discourse-meta&utm_campaign=how-to-generate-facebook-page-posts-for-new-discourse-posts-app-partner-community&utm_keyword=use%20case%20article%202
:link: https://support.integromat.com/hc/en-us/articles/360019209860-discourse?utm_medium=partner&utm_source=discourse-meta&utm_campaign=how-to-generate-facebook-page-posts-for-new-discourse-posts-app-partner-community&utm_keyword=use%20case%20article%202%20-%20support
:link: https://www.integromat.com/en/ticket?utm_medium=partner&utm_source=discourse-meta&utm_campaign=how-to-generate-facebook-page-posts-for-new-discourse-posts-app-partner-community&utm_keyword=use%20case%20article%202%20-%20ticket
:link: https://www.integromat.com/en/register?utm_medium=partner&utm_source=discourse-meta&utm_campaign=how-to-generate-facebook-page-posts-for-new-discourse-posts-app-partner-community&utm_keyword=use%20case%20article%202
:link: How to Connect Discourse with Hundreds of Apps Using Integromat
:link: https://www.integromat.com/en/integration/4978-create-topics-in-discourse-from-wordpress-posts?utm_medium=partner&utm_source=disocurse-meta&utm_campaign=how-to-connect-discourse-with-hundreds-of-apps-using-integromat-app-partner-community
:link: How to Get an Email Notification When a New User Signs Up
:link: https://www.integromat.com/en/integration/4985-share-new-discourse-posts-as-messages-in-a-facebook-group?utm_medium=partner&utm_source=discourse-meta&utm_campaign=how-to-connect-discourse-with-hundreds-of-apps-using-integromat-app-partner-community
7 Mi Piace
L’ho appena configurato e ci ho messo meno di 10 minuti. Ho creato uno scenario per “Nuovi argomenti pubblicano un messaggio sul gruppo FB”, ho testato un nuovo argomento e ho eseguito manualmente lo scenario. Il post è apparso subito. Attualmente l’ho impostato su un timer di 15 minuti e lo perfezionerò man mano che otterrò più dati.
Bello.
2 Mi Piace
Ciao @rmccown, fantastico! Sono molto felice di sentire che tutto funziona bene per te :slightly_smiling_face:
1 Mi Piace
Una cosa che ho notato stamattina. Ho impostato un’azione “watch topics” per quando viene creato un nuovo argomento. Non è disponibile un nome “creato dall’utente”, solo il nome dell’ultimo utente che ha postato, che potrebbe essere diverso se qualcuno ha risposto al post tra il momento in cui è stato creato e quando la regola si attiva.
1 Mi Piace
Ciao di nuovo @rmccown :wave:
Capisco perfettamente cosa stai dicendo.
Per ottenere i dettagli dell’utente, dovresti aggiungere il modulo ‘Get a Topic’ dopo quello ‘Watch Topics’.
(L’ID dell’argomento viene mappato nel modulo ‘Get a Topic’)
1 Mi Piace
Grazie, sembra aver funzionato.
1 Mi Piace
Ogni volta che aggiungi nuovi post in Discourse, Make recupererà automaticamente i post e li condividerà su una pagina di Facebook, inoltre il pannello smm aiuta molto per gli strumenti di social media marketing.
