Hey,
How do you hide sub categories in the hamburger menu ?
Hey,
Seems like that is controlled by show subcategory list in site settings…
I’m sorry can you explain ?
If you go into you admin panel, you should have a settings tab. Search for show subcategory list and enable it. That will remove subcategories from the hamburger menu and instead display them on the category page.
Ah great that worked
