如何使用 CSS 隐藏 Staff 分类?
I am hosting a discourse install that is acting as a wiki for 2 people. I don’t need the staff category for this purpose - its just cluttering up the screen.
I can use the following css to hide it on the desktop:
// hide staff category
tr[data-category-id="3"] {
    display: none;
This doesn’t work on mobile though. Does anyone know how to hide the staff category on mobile?
1 个赞
Try
tr[data-category-id="3"],
category[data-category-id="3"]  {
    display: none;
3 个赞
That didn’t seem to work. This did:
.category-list-item[data-category-id="3"]  {
display: none;
1 个赞
Unfortunately, there are still staff posts appearing in search. I looked at the css, and managed to narrow down the section using this:
.fps-result .author a[data-user-card=“system”] {
but it seems that there is no current way to select the parent class in the css spec (though its in a future spec), so I don’t see how it’s possible to hide these search entries without changes to the way discourse styles entries on the search pages.
Completely trying to hide a un-deletable category which exists specifically for staff seems difficult.
If it’s bothering you that much, I guess you could use as a main account a new one with a trust level 4, and log in with your admin account only when you have to do admin stuff.
2 个赞
Maybe make those users not be staff?
2 个赞
