Hi, Discourse looks like a great solution for my website, and I would like to test the Discourse plugin for Wordpress (to replace the comment system). However, I’m not sure how to run/install it to work with my local MAMP Wordpress site.
What would be the best way to get this up and running locally (with Wordpress via MAMP on MacOs)?
Have a look at https://kitematic.com/ which makes it easy to run and manage docker containers locally on MacOS and Windows. After installing it on your Mac do a search for discourse and create a new container, you should then be able to hook up your Wordpress on MAMP with Discourse easily enough, it’s pretty straightforward.
