New install nginx errors
Kyle3 is experiencing nginx errors during a new Discourse installation on Ubuntu 20.04.3 LTS, specifically an ‘invalid variable name’ error in /etc/nginx/conf.d/discourse.conf when SSL is enabled. The issue appears to stem from the forum host variable, preventing connections. Hardcoding the URL in a custom nginx template allows the site to load but results in mixed resource errors due to a Content Security Policy (CSP) violation, as scripts are referenced from an incorrect domain. Disabling CSP resolves some issues but not the underlying address mismatch. Kyle3 seeks advice on resolving these SSL and CSP-related problems.
I’m trying to set up on a clean install on Ubuntu 20.04.3 LTS
This is on a virtual machine inside a corporate network, the DNS A records point to the firewall that will use host headers to direct to the server, the internal IP address is different to the external.
Currently, for set up, there is an internal network DNS entry that is resolved internally, that the server can resolve and other machines can access on the network.
I have installed a wildcard certificate as instructed here: How to install SSL certificate in Discourse - support - Discourse Meta which works without issue.
I have installed using the 30 minute quick start guide.
The problem
The forum functions correctly when disabling SSL. However with SSL enabled nginx errors with invalid variable name in /etc/nginx/conf.d/discourse.conf:46 this clearly relates to the the forum host variable and connections are impossible.
I have tried creating a nginx template with the url hardcoded, and this does then load the site, however I then get mixed resource errors and none of the JavaScript loads as it violates the CSP:
because it violates the following Content Security Policy directive: "script-src https://www.example.com/logs/ ...
I can disable CSP and things broadly work (though there are still references to the manifest at example.com), but I’d rather not and it doesn’t fix the resources at the incorrect address
Any advice would be very much appreciated!
