@sam I managed to install the snappy gem by executing apt install libsnappy-dev, but I’m not sure what’s missing in order to install the bootsnap gem on my Ubuntu 16.10 machine. What’s the trick to get this working? ![]()
I’m getting the following error:
error: enumerator value for ‘RUBY_FL_USER19’ is not an integer constant expression [-Werror=pedantic]
The complete logfile:
current directory: /home/gerhard/.rbenv/versions/2.3.0/lib/ruby/gems/2.3.0/gems/bootsnap-0.2.10/ext/bootsnap
/home/gerhard/.rbenv/versions/2.3.0/bin/ruby -r ./siteconf20170425-62270-exmesk.rb extconf.rb
creating Makefile
make "DESTDIR=" clean
make "DESTDIR="
compiling bootsnap.c
In file included from /home/gerhard/.rbenv/versions/2.3.0/include/ruby-2.3.0/ruby.h:33:0,
from bootsnap.h:6,
from bootsnap.c:1:
/home/gerhard/.rbenv/versions/2.3.0/include/ruby-2.3.0/ruby/ruby.h:834:45: error: enumerator value for ‘RUBY_FL_USER19’ is not an integer constant expression [-Werror=pedantic]
#define RUBY_FL_USER_N(n) RUBY_FL_USER##n = (1<<(RUBY_FL_USHIFT+n))
/home/gerhard/.rbenv/versions/2.3.0/include/ruby-2.3.0/ruby/ruby.h:855:5: note: in expansion of macro ‘RUBY_FL_USER_N’
RUBY_FL_USER_N(19),
In file included from /home/gerhard/.rbenv/versions/2.3.0/include/ruby-2.3.0/ruby/ruby.h:1985:0,
from /home/gerhard/.rbenv/versions/2.3.0/include/ruby-2.3.0/ruby.h:33,
from bootsnap.h:6,
from bootsnap.c:1:
/home/gerhard/.rbenv/versions/2.3.0/include/ruby-2.3.0/ruby/intern.h:922:29: error: ‘struct timespec’ declared inside parameter list will not be visible outside of this definition or declaration [-Werror]
void rb_timespec_now(struct timespec *);
/home/gerhard/.rbenv/versions/2.3.0/include/ruby-2.3.0/ruby/intern.h:925:41: error: ‘struct timespec’ declared inside parameter list will not be visible outside of this definition or declaration [-Werror]
VALUE rb_time_timespec_new(const struct timespec *, int);
cc1: error: unrecognized command line option ‘-Wno-keyword-macro’ [-Werror]
cc1: all warnings being treated as errors
Makefile:238: recipe for target 'bootsnap.o' failed
make: *** [bootsnap.o] Error 1
make failed, exit code 2
