I’m running 2.4.0.beta8 (8a6421565e in a docker deployment built about a month and a half ago), and I am trying to merge two user records:
time bin/rake 'users:merge[old_name,new_name]'
rake aborted!
LoadError: cannot load such file -- rb-inotify
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/loaded_features_index.rb:89:in `register'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:40:in `rescue in require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:26:in `require'
/var/www/discourse/config/application.rb:55:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies.rb:325:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies.rb:291:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies.rb:325:in `require'
/var/www/discourse/Rakefile:7:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:54:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies.rb:319:in `block in load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies.rb:319:in `load'
Caused by:
Bootsnap::LoadPathCache::FallbackScan:
Is this a current bug, or is this launcher rebuild app time?
