My forum is in the read-only mode now, as an administrator, if I cannot log in then I cannot close the read-only mode. But when I log in it shows: the forum is in the read-only mode now, so I cannot log in.
I’m not sure, but can’t the /u/admin-login path bypass read-only? ![]()
Hi,
If you don’t have the browser window open where you enabled read-only mode, you’ll need to disable read-only mode via command line
Here is some help:
cannot, it showed this to me
{"errors":["The site is in read only mode. Interactions are disabled."],"error_type":"read_only"}
