Accidentally made site read only, how do I disable?
hello,
I actived the function read only on the discourse forum, but i logged out and now, i can’t able to reconnect to the forum.
What is it the solution please ?
Found this via searches.
So basically, executing this in rails console:
Discourse.disable_readonly_mode(Discourse::USER_READONLY_MODE_KEY)
will get you out of readonly mode, and then you can login.
Moral of the story? Don’t log out after activating readonly mode.
how to log in rails console ? i installed ruby-railties
Yup this should’ve done it. Do you have access to your site login now?
all is good thanx my brother
