Wie man aktive Nutzer misst?
How does everyone measure active/super active users? ie people who have logged in or commented in the past month, for example.
The dashboard tells me the number of visits and comments etc, but I don’t know how to chunk this down easily into actual users. We’ve got 1400 members on our community, but I’d like to know how many of those are engaging with it month on month.
Thanks,
Sian
The data explorer plugin will let you look at the data in a more granular fashion than the basic information which admin>dashboard shows.
See, for example, Active users in the last 30 days
Oo sounds interesting, how do I go about setting that up? I’m not a developer so have no idea where to begin.
See “Installation” at the bottom of: Discourse Data Explorer
These queries will help:
Top 50 posters
Returns the top 50 posters for a given monthly period. Results are ordered by post_count. It accepts a ‘months_ago’ parameter, defaults to 1 to give results for the most recently completed calendar month.
-- [params]
-- int :months_ago = 1
WITH query_period AS (
SELECT
date_trunc('month', CURRENT_DATE) - INTERVAL ':months_ago months' as period_start,
date_trunc('month', CURRENT_DATE) - INTERVAL ':months_ago months' + INTERVAL '1 month' - INTERVAL '1 second' as period_end
user_posts_in_period AS (
SELECT
p.user_id
FROM posts p
INNER JOIN query_period qp
ON p.created_at >= qp.period_start
AND p.created_at <= qp.period_end
WHERE p.user_id > 0
SELECT
up.user_id,
count(1) as post_count
FROM user_posts_in_period up
GROUP BY up.user_id
ORDER BY post_count DESC
LIMIT 50
Top 50 likers
Returns the top 50 likers for a given monthly period. Results are ordered by like_count. It accepts a ‘months_ago’ parameter, defaults to 1 to give results for the most recently completed calendar month.
-- [params]
SELECT
SELECT
ua.user_id,
count(1) AS like_count
FROM user_actions ua
ON ua.created_at >= qp.period_start
AND ua.created_at <= qp.period_end
WHERE ua.action_type = 1
GROUP BY ua.user_id
ORDER BY like_count DESC
LIMIT 50
you could also get in touch with @DiscourseMetrics.com and @Bas (about Community Analytics)
their tools can give you loads of extra stats so you don’t have to do the work … I’m looking at such tools at the moment myself
Up till now I’ve been doing this just in excel - you can export your user data and run a few queries to monitor this. I gave a value to each post read, to posts (replies) and to new threads, then categorised them accordingly
So far it shows 20% are ‘readers’, 25% are ‘participants’ and 15% are ‘creators’
I’ve found that most analysis tools are under-valuing the role of readers because of a focus just on the activity of posting. There is a big difference between inactive members and active readers!
Good luck!
I think you are correct in saying this.
There are ways (e.g. separating logged in/out users, measuring read time, collating paged threads etc.) to guide Google Analytics to do quite a bit of this for you; but it takes some proper GA-fu to accomplish.
Great queries Sarah! Thanks for share.
I updated the query list, if you have more to add, please just send PR :pray:
Thanks again !
I can’t take credit – @simon wrote them.
Wie erhalte ich die täglichen Zählungen basierend auf eindeutigen IPs?
Basiert das Dashboard > Benutzerbesuche auf IPs (einschließlich angemeldeter Benutzer und Besucher)?
Danke…
Ich glaube nicht. Es geht um angemeldete Benutzer.
Sie können sich auch What is "user visits" on the admin dashboard? ansehen.
Ich denke, dies ist ähnlich dem, wonach Sie suchen. Da Sie alle Benutzer und nicht nur anonyme Benutzer wünschen, müssten Sie die Bedingung entfernen, dass der Benutzer anonym ist.
In der Benutzerliste haben wir diese Statistiken:
Benutzername, Zuletzt E-Mail gesendet, Gesehen, Angesehene Themen, Gelesene Beiträge, Lesezeit, Erstellt
Wäre es möglich, Folgendes hinzuzufügen:
Anzahl der erstellten Themen, Anzahl der erstellten Beiträge, Anzahl der gegebenen Likes, Anzahl der erhaltenen Likes.
Diese sind nützlich, um die aktivsten Mitwirkenden zu messen.
Diese sind alle in Discourse Meta enthalten
Danke. Es scheint, dass es für das Benutzerverzeichnis vorhanden ist, aber nicht in der Admin-Benutzerliste unter
https://meta.discourse.org/admin/users/list/active
Ich frage mich, ob dieselben Felder in der Admin-Ansicht angezeigt werden könnten oder ob das Benutzerverzeichnis (wenn in den Einstellungen deaktiviert) immer noch von Admins eingesehen werden kann, sodass diese zusätzlichen Details sichtbar sind.
[quote=“Robert McIntosh, post:8, topic:74574, full:true, username:robmc”]Sie können sich auch an @DiscourseMetrics.com und @Bas (über Community Analytics) wenden.
Ihre Tools können Ihnen viele zusätzliche Statistiken liefern, sodass Sie die Arbeit nicht selbst erledigen müssen… Ich schaue mir selbst gerade solche Tools an.
Bisher habe ich das nur in Excel gemacht – Sie können Ihre Benutzerdaten exportieren und einige Abfragen ausführen, um dies zu überwachen. Ich habe jedem gelesenen Beitrag, jedem Beitrag (Antworten) und jedem neuen Thread einen Wert zugewiesen und sie dann entsprechend kategorisiert.
Bisher zeigt sich, dass 20 % „Leser“, 25 % „Teilnehmer“ und 15 % „Ersteller“ sind.
Ich habe festgestellt, dass die meisten Analysetools die Rolle der Leser unterschätzen, da sie sich nur auf die Posting-Aktivität konzentrieren. Es gibt einen großen Unterschied zwischen inaktiven Mitgliedern und aktiven Lesern!
Viel Erfolg!
[/quote]
Hallo, ich habe gerade diesen Thread gesehen. Wenn Sie hier sind, können Sie mir bitte sagen, welche Tools helfen können, das Engagement in der Community über reine Posting-Aktivitäten hinaus zu verfolgen, insbesondere zur Messung aktiver Leser?
Vielen Dank,
Mike Taku.
Kann ich für diese Poster und Liker einen Badge erstellen?
