如何将 DigitalOcean Droplet 迁移至另一个 DigitalOcean 账户中的 Droplet
按照 Move your Discourse Instance to a Different Server 的说明,我在 Discourse 中创建了备份,并将其恢复到了新的 Discourse 实例上。但新实例的内容或其他方面并未受到影响。我是否需要根据旧实例配置新实例的数据库,或者还有其他需要完成的操作?
新实例是基于 https://yunohost.org 安装在 DigitalOcean Droplet 上的。
编辑:刚刚发现了这个提示:Move your Discourse Instance to a Different Server - #74
因此我启用了该选项,但恢复失败,日志如下:[2020-05-23 22:04:50] [STARTED][2020-05-23 22:04:50] 'okr' has started the res - Pastebin.com
有人对此有什么建议吗?
1 个赞
This error is pretty clear
[2020-05-23 22:04:50] EXCEPTION: You're trying to restore a more recent version of the schema. You should migrate first!
The Discourse installed via YunoHost is not the last version of Discourse, this type of installations is not supported here, so, you’ll receive really limited help.
5 个赞
Ah, thanks a lot for your assistance!
2 个赞
