Comment peupler un serveur de développement avec des données de Production ?
Guys,
I wonder if there is ‘correct way’ to upload some test data from a Production forum back-up into a dev server.
Obviously the dev server will lack a domain.
I’m using a cloud server for dev.
What are the gotchas here?
I guess it’s lacking Productions app.yml so there should be no risk of it shooting off emails?
Thanks! … Sorry! Found a guide here:
Emails are disabled during an import. Once it is finished you can just use the disable_emails site setting.
