Discourse DEV backup verplaatsen naar Productie?
All the issues i managed to fix with the import scripts by using a dev env instead of production, how can i go about moving the imported content on a exported .sql backup from the dev env to a production env? is it just as simple as exporting the .sql backup file and then installing a production env and importing the backup?
Yes. :grinning_face:
There are other ways that do the job:
  • database replication
  • rsync the entire server
  • point the production url at dev
But restoring backups (especially if they are stored on S3) is easy.
Make sure to backup uploads too if they aren’t on S3.
To preserve the attachments and uploads, use discourse built in backup/restore functionality to backup from dev and restore to production
