איך לשחזר את האתר שלך מגניבה בטרמינל?
I did a backup of my site before I installed the plugin “Topic List Previews” however the installation was unsuccessful and I can’t even access my site. Is there anyway that I can restore my site from the backup that I created earlier from terminal app as I can’t access the site?
I uploaded clean app.yml file, which is verified as VALID YML file.
It keeps saying FAILED when I tried to rebuilt app with the following command
cd /var/docker
./launcher rebuild app
Ensuring discourse docker is up to date
Fetching origin
Discourse Docker is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 10 app
app
cd /pups && git pull && /pups/bin/pups --stdin
Already up-to-date.
I, [2016-04-07T13:12:59.638922 #37]  INFO -- : Loading --stdin
I, [2016-04-07T13:12:59.657799 #37]  INFO -- : > mkdir -p /shared/postgres_run
I, [2016-04-07T13:12:59.662457 #37]  INFO -- :
I, [2016-04-07T13:12:59.664087 #37]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2016-04-07T13:12:59.670683 #37]  INFO -- :
I, [2016-04-07T13:12:59.672528 #37]  INFO -- : > chmod 775 /shared/postgres_run
I, [2016-04-07T13:12:59.681308 #37]  INFO -- :
I, [2016-04-07T13:12:59.683887 #37]  INFO -- : > rm -fr /var/run/postgresql
I, [2016-04-07T13:12:59.690690 #37]  INFO -- :
I, [2016-04-07T13:12:59.693529 #37]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2016-04-07T13:12:59.700144 #37]  INFO -- :
I, [2016-04-07T13:12:59.702802 #37]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2016/04/07 13:12:59 socat[45] E connect(4, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2016-04-07T13:12:59.714697 #37]  INFO -- :
I, [2016-04-07T13:12:59.716867 #37]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2016-04-07T13:12:59.723967 #37]  INFO -- :
I, [2016-04-07T13:12:59.726387 #37]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2016-04-07T13:12:59.732756 #37]  INFO -- :
I, [2016-04-07T13:12:59.735259 #37]  INFO -- : > mkdir -p /shared/postgres_run/9.3-main.pg_stat_tmp
I, [2016-04-07T13:12:59.741575 #37]  INFO -- :
I, [2016-04-07T13:12:59.744293 #37]  INFO -- : > chown postgres:postgres /shared/postgres_run/9.3-main.pg_stat_tmp
I, [2016-04-07T13:12:59.750943 #37]  INFO -- :
I, [2016-04-07T13:12:59.761476 #37]  INFO -- : File > /etc/service/postgres/run  chmod: +x
I, [2016-04-07T13:12:59.769827 #37]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x
I, [2016-04-07T13:12:59.778836 #37]  INFO -- : File > /root/upgrade_postgres  chmod: +x
I, [2016-04-07T13:12:59.782416 #37]  INFO -- : > chown -R root /var/lib/postgresql/9.3/main
I, [2016-04-07T13:13:00.326847 #37]  INFO -- :
I, [2016-04-07T13:13:00.327310 #37]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/9.3/bin/initdb -D /shared/postgres_data || exit 0
I, [2016-04-07T13:13:00.330970 #37]  INFO -- :
I, [2016-04-07T13:13:00.331749 #37]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2016-04-07T13:13:00.361666 #37]  INFO -- :
I, [2016-04-07T13:13:00.362695 #37]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2016-04-07T13:13:00.367174 #37]  INFO -- :
I, [2016-04-07T13:13:00.368717 #37]  INFO -- : > /root/upgrade_postgres
I, [2016-04-07T13:13:00.377007 #37]  INFO -- :
I, [2016-04-07T13:13:00.378738 #37]  INFO -- : > rm /root/upgrade_postgres
I, [2016-04-07T13:13:00.382257 #37]  INFO -- :
I, [2016-04-07T13:13:00.384302 #37]  INFO -- : Replacing data_directory = '/var/lib/postgresql/9.3/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.386481 #37]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.387968 #37]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.389931 #37]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.392016 #37]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.394363 #37]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.397727 #37]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2016-04-07T13:13:00.403875 #37]  INFO -- :
I, [2016-04-07T13:13:00.405215 #37]  INFO -- : Replacing (?-mix:#?max_wal_senders *=.*) with max_wal_senders = $db_max_wal_senders in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.407397 #37]  INFO -- : Replacing (?-mix:#?wal_level *=.*) with wal_level = $db_wal_level in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.409789 #37]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.411867 #37]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.414036 #37]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/9.3/main/postgresql.conf
I, [2016-04-07T13:13:00.419999 #37]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/9.3/main/pg_hba.conf
I, [2016-04-07T13:13:00.421992 #37]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/9.3/main/pg_hba.conf
I, [2016-04-07T13:13:00.423953 #37]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.3/bin/postmaster -D /etc/postgresql/9.3/main
I, [2016-04-07T13:13:00.452980 #37]  INFO -- : > sleep 5
2016-04-07 13:13:00 UTC [69-1] LOG:  database system was shut down at 2016-04-07 12:56:59 UTC
2016-04-07 13:13:00 UTC [69-2] LOG:  MultiXact member wraparound protections are now enabled
2016-04-07 13:13:00 UTC [66-1] LOG:  database system is ready to accept connections
2016-04-07 13:13:00 UTC [73-1] LOG:  autovacuum launcher started
I, [2016-04-07T13:13:05.463961 #37]  INFO -- :
I, [2016-04-07T13:13:05.465053 #37]  INFO -- : > su postgres -c 'createdb discourse' || true
2016-04-07 13:13:05 UTC [78-1] postgres@postgres ERROR:  database "discourse" already exists
2016-04-07 13:13:05 UTC [78-2] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: database creation failed: ERROR:  database "discourse" already exists
I, [2016-04-07T13:13:05.553175 #37]  INFO -- :
I, [2016-04-07T13:13:05.554051 #37]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2016-04-07 13:13:05 UTC [89-1] postgres@discourse ERROR:  role "discourse" already exists
2016-04-07 13:13:05 UTC [89-2] postgres@discourse STATEMENT:  create user discourse;
I, [2016-04-07T13:13:05.620490 #37]  INFO -- :
I, [2016-04-07T13:13:05.621525 #37]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2016-04-07T13:13:05.689727 #37]  INFO -- : GRANT
I, [2016-04-07T13:13:05.690759 #37]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2016-04-07T13:13:05.751776 #37]  INFO -- : ALTER SCHEMA
I, [2016-04-07T13:13:05.752741 #37]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2016-04-07T13:13:05.827553 #37]  INFO -- : CREATE EXTENSION
I, [2016-04-07T13:13:05.828642 #37]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2016-04-07T13:13:05.897043 #37]  INFO -- : CREATE EXTENSION
I, [2016-04-07T13:13:05.898402 #37]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2016-04-07T13:13:05.971137 #37]  INFO -- : CREATE EXTENSION
I, [2016-04-07T13:13:05.971980 #37]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2016-04-07T13:13:06.032009 #37]  INFO -- : CREATE EXTENSION
I, [2016-04-07T13:13:06.033483 #37]  INFO -- : > sudo -u postgres psql discourse
I, [2016-04-07T13:13:06.036669 #37]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2016-04-07T13:13:06.125869 #37]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x
I, [2016-04-07T13:13:06.131517 #37]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:
I, [2016-04-07T13:13:06.132832 #37]  INFO -- : > echo postgres installed!
I, [2016-04-07T13:13:06.135861 #37]  INFO -- : postgres installed!
I, [2016-04-07T13:13:06.143046 #37]  INFO -- : File > /etc/service/redis/run  chmod: +x
I, [2016-04-07T13:13:06.147207 #37]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x
I, [2016-04-07T13:13:06.148022 #37]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2016-04-07T13:13:06.149225 #37]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2016-04-07T13:13:06.150465 #37]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2016-04-07T13:13:06.153201 #37]  INFO -- :
I, [2016-04-07T13:13:06.153860 #37]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2016-04-07T13:13:06.155232 #37]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2016-04-07T13:13:06.156578 #37]  INFO -- : > echo redis installed
I, [2016-04-07T13:13:06.158645 #37]  INFO -- : redis installed
I, [2016-04-07T13:13:06.159522 #37]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2016-04-07T13:13:06.222739 #37]  INFO -- :
I, [2016-04-07T13:13:06.223604 #37]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2016-04-07T13:13:06.291279 #37]  INFO -- :
I, [2016-04-07T13:13:06.297151 #37]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x
I, [2016-04-07T13:13:06.301808 #37]  INFO -- : File > /etc/runit/1.d/ensure-web-nginx-read  chmod: +x
I, [2016-04-07T13:13:06.306289 #37]  INFO -- : File > /etc/service/unicorn/run  chmod: +x
I, [2016-04-07T13:13:06.310982 #37]  INFO -- : File > /etc/service/nginx/run  chmod: +x
I, [2016-04-07T13:13:06.315465 #37]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x
I, [2016-04-07T13:13:06.320023 #37]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x
I, [2016-04-07T13:13:06.320479 #37]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2016-04-07T13:13:06.321758 #37]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2016-04-07T13:13:06.328126 #37]  INFO -- : > cd /var/www/discourse && git reset --hard
194:M 07 Apr 13:13:06.338 * Redis 3.0.6 (00000000/0) 64 bit, standalone mode, port 6379, pid 194 ready to start.
194:M 07 Apr 13:13:06.338 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
194:M 07 Apr 13:13:06.338 # Server started, Redis version 3.0.6
194:M 07 Apr 13:13:06.338 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
194:M 07 Apr 13:13:06.339 # WARNING you have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command 'echo never > /sys/kernel/mm/transparent_hugepage/enabled' as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled.
194:M 07 Apr 13:13:06.422 * DB loaded from disk: 0.083 seconds
194:M 07 Apr 13:13:06.423 * The server is now ready to accept connections on port 6379
I, [2016-04-07T13:13:07.515459 #37]  INFO -- : HEAD is now at 13e1bf8 Merge pull request #4023 from dandv/patch-1
I, [2016-04-07T13:13:07.515650 #37]  INFO -- : > cd /var/www/discourse && git clean -f
I, [2016-04-07T13:13:07.545681 #37]  INFO -- :
I, [2016-04-07T13:13:07.546174 #37]  INFO -- : > cd /var/www/discourse && git remote set-branches --add origin master
I, [2016-04-07T13:13:07.553736 #37]  INFO -- :
I, [2016-04-07T13:13:07.553925 #37]  INFO -- : > cd /var/www/discourse && git pull
From https://github.com/discourse/discourse
   13e1bf8..3d4cdd7  master     -> origin/master
 * [new branch]      add_host_to_nginx_log -> origin/add_host_to_nginx_log
   35d6e64..d61fcbb  beta       -> origin/beta
 * [new branch]      flexheader -> origin/flexheader
 * [new branch]      like-badges -> origin/like-badges
   9f56d61..aa91e4c  stable     -> origin/stable
 * [new branch]      tableheader -> origin/tableheader
   13e1bf8..2ecff60  tests-passed -> origin/tests-passed
   e848ea5..03068e3  vdom       -> origin/vdom
 * [new tag]         v1.5.0     -> v1.5.0
 * [new tag]         v1.4.6     -> v1.4.6
 * [new tag]         v1.4.7     -> v1.4.7
 * [new tag]         v1.5.0.beta11 -> v1.5.0.beta11
 * [new tag]         v1.5.0.beta12 -> v1.5.0.beta12
 * [new tag]         v1.5.0.beta13 -> v1.5.0.beta13
 * [new tag]         v1.5.0.beta13b -> v1.5.0.beta13b
 * [new tag]         v1.5.0.beta14 -> v1.5.0.beta14
 * [new tag]         v1.6.0.beta1 -> v1.6.0.beta1
I, [2016-04-07T13:13:24.960236 #37]  INFO -- : Updating 13e1bf8..3d4cdd7
Fast-forward
 1669 files changed, 39318 insertions(+), 33997 deletions(-)
I, [2016-04-07T13:13:24.961182 #37]  INFO -- : > cd /var/www/discourse && git fetch origin tests-passed
 * branch            tests-passed -> FETCH_HEAD
I, [2016-04-07T13:13:28.699175 #37]  INFO -- :
I, [2016-04-07T13:13:28.700500 #37]  INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2016-04-07T13:13:29.010282 #37]  INFO -- : Branch tests-passed set up to track remote branch tests-passed from origin.
I, [2016-04-07T13:13:29.010459 #37]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2016-04-07T13:13:29.013684 #37]  INFO -- :
I, [2016-04-07T13:13:29.013928 #37]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2016-04-07T13:13:29.016610 #37]  INFO -- :
I, [2016-04-07T13:13:29.016763 #37]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2016-04-07T13:13:29.020106 #37]  INFO -- :
I, [2016-04-07T13:13:29.020547 #37]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2016-04-07T13:13:29.023488 #37]  INFO -- :
I, [2016-04-07T13:13:29.023648 #37]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr}.log"
I, [2016-04-07T13:13:29.028027 #37]  INFO -- :
I, [2016-04-07T13:13:29.028484 #37]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr}.log /var/www/discourse/log"
I, [2016-04-07T13:13:29.032781 #37]  INFO -- :
I, [2016-04-07T13:13:29.032977 #37]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2016-04-07T13:13:29.037350 #37]  INFO -- :
I, [2016-04-07T13:13:29.037557 #37]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2016-04-07T13:13:29.044369 #37]  INFO -- :
I, [2016-04-07T13:13:29.044547 #37]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups
I, [2016-04-07T13:13:29.050409 #37]  INFO -- :
I, [2016-04-07T13:13:29.050917 #37]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2016-04-07T13:13:29.052795 #37]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2016-04-07T13:13:37.957704 #37]  INFO -- :
I, [2016-04-07T13:13:37.960429 #37]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2016-04-07T13:13:37.968777 #37]  INFO -- :
I, [2016-04-07T13:13:37.969837 #37]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2016-04-07T13:13:37.973925 #37]  INFO -- :
I, [2016-04-07T13:13:37.974658 #37]  INFO -- : > mkdir -p /var/nginx/cache
I, [2016-04-07T13:13:37.978178 #37]  INFO -- :
I, [2016-04-07T13:13:37.979228 #37]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2016-04-07T13:13:37.980407 #37]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2016-04-07T13:13:37.981526 #37]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2016-04-07T13:13:37.982550 #37]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2016-04-07T13:13:37.983886 #37]  INFO -- : > echo "done configuring web"
I, [2016-04-07T13:13:37.986329 #37]  INFO -- : done configuring web
I, [2016-04-07T13:13:37.988007 #37]  INFO -- : > cd /var/www/discourse && gem update bundler
ERROR:  While executing gem ... (Gem::RemoteFetcher::UnknownHostError)
    no such name (https://api.rubygems.org/specs.4.8.gz)
I, [2016-04-07T13:13:43.394943 #37]  INFO -- : Updating installed gems
I, [2016-04-07T13:13:43.396171 #37]  INFO -- : Terminating async processes
I, [2016-04-07T13:13:43.396329 #37]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.3/bin/postmaster -D /etc/postgresql/9.3/main pid: 66
2016-04-07 13:13:43 UTC [66-2] LOG:  received fast shutdown request
2016-04-07 13:13:43 UTC [66-3] LOG:  aborting any active transactions
2016-04-07 13:13:43 UTC [73-2] LOG:  autovacuum launcher shutting down
2016-04-07 13:13:43 UTC [70-1] LOG:  shutting down
I, [2016-04-07T13:13:43.402942 #37]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 194
194:signal-handler (1460034823) Received SIGTERM scheduling shutdown...
2016-04-07 13:13:43 UTC [70-2] LOG:  database system is shut down
194:M 07 Apr 13:13:43.475 # User requested shutdown...
194:M 07 Apr 13:13:43.476 * Saving the final RDB snapshot before exiting.
194:M 07 Apr 13:13:43.605 * DB saved on disk
194:M 07 Apr 13:13:43.605 # Redis is now ready to exit, bye bye...
FAILED
RuntimeError: cd /var/www/discourse && gem update bundler failed with return #<Process::Status: pid 284 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem update bundler", "chown -R discourse $home"]}
50a6d1ca4e22de3ddbc46d24e025c6731c074f94b70474701f717e8fb9818725
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Any help is greatly appreciated.
This is the error which leads to a DNS error in the container.
Do you try to set DNS servers for Docker?
If the answer is yes, and the problem remains, check /etc/hosts to make sure everything is fine there.
If the problem still remains, call your server provider for help. It’s their responsibility for maintaining the network.
I don’t think that was my intention. All I did was tried to install the plugin and it failed. Now I can’t even access my site. I removed the plugin from app.yml and tried to rebuild the app. I don’t know how to fix it as I am not programmer.
That’s exactly what I am intended to say. The DNS error prevent your site from rebuilding! (that’s why you see the FAILED error)
Once you fixed the DNS problem, your site would come back into life again. (which might also help you install the plugin)
Thanks. How to fix my DNS? I am using digitalocean.com as my hosting company.
Follow the link. There is a detailed step showing how to do that. (1 - 5)
For step 3, use DOCKER_OPTS="--dns 8.8.8.8 --dns 8.8.4.4" as this suggests:
@fantasticfears
Thank you so much for your help. I was able to fix the issue here by following your guideline that you provided for me. My site is online again.
:grinning:
