I’m looking to use the search API to find all tags that match a string but have no tags. Is this possible? My hope is that this would work similar to in:solved (How to search and filter solved/unsolved topics?).
More generally, is there a list of all such search terms? (Happy to look at code if someone could provide a pointer.)
Thanks! The advanced filters starting around line 269 are very useful:
advanced_filter(/^status:open$/) do |posts|
advanced_filter(/^status:closed$/) do |posts|
advanced_filter(/^status:archived$/) do |posts|
advanced_filter(/^status:noreplies$/) do |posts|
advanced_filter(/^status:single_user$/) do |posts|
advanced_filter(/^in:first|^f$/) do |posts|
advanced_filter(/^in:pinned$/) do |posts|
advanced_filter(/^in:unpinned$/) do |posts|
advanced_filter(/^in:(likes|bookmarks)$/) do |posts, match|
advanced_filter(/^in:posted$/) do |posts|
advanced_filter(/^in:seen$/) do |posts|
advanced_filter(/^in:unseen$/) do |posts|
advanced_filter(/^in:wiki$/) do |posts, match|
advanced_filter(/^posts_count:(\d+)$/) do |posts, match|
advanced_filter(/^min_post_count:(\d+)$/) do |posts, match|
advanced_filter(/^badge:(.*)$/) do |posts, match|
advanced_filter(/^with:images$/) do |posts|
advanced_filter(/^\#([\p{L}0-9\-:=]+)$/) do |posts, match|
advanced_filter(/^group:(.+)$/) do |posts, match|
advanced_filter(/^user:(.+)$/) do |posts, match|
advanced_filter(/^\@([a-zA-Z0-9_\-.]+)$/) do |posts, match|
advanced_filter(/^before:(.*)$/) do |posts, match|
advanced_filter(/^after:(.*)$/) do |posts, match|
advanced_filter(/^tags?:([\p{L}0-9,\-_+]+)$/) do |posts, match|
advanced_filter(/^\-tags?:([\p{L}0-9,\-_+]+)$/) do |posts, match|
advanced_filter(/^filetypes?:([a-zA-Z0-9,\-_]+)$/) do |posts, match|
I assume “solved”/“unsolved” would show up in the plugin code, eh?
Interesting. Thanks. We’re currently looking for an API solution for auto-generating a list of all topics that we need to respond to.
Yup, that’s where I started and ended up wanting more Very useful.
Is there a technical reason (performance of the query, etc.) that an in:untagged advanced filter wouldn’t work?
