How to show badge publicly?
The discussion revolves around making badges visible on the public badges page. Overgrow asks why they can’t enable the ‘Show badge on the public badges page’ option for standard badges like Anniversary, noting that the setting doesn’t seem to work and the badges are read-only. ondrej clarifies that the option is checked by default for core badges, but the checkmark is faint and may appear unchecked. Overgrow confirms that system badges (with system = true in the database) are not editable. ondrej agrees, stating the option is greyed out and not editable. HamMan2118 adds that system badges have limited editability and suggests disabling them if public visibility is not desired.
Admin → Badges.
Can you please advise how to make checkboxes next to the standard badges (like Anniversary) active?
I can’t set Show badge on the public badges page for some reason.
Badges SQL editable settings doesn’t have any influence and I’m not able to find any other setting in the Admin Settings.
I must be overlooking something obvious.. Thanks.
Hey :slight_smile:
Show badge on the public badges page is checked by default on the anniversary badge like all other default badges in core.
The checkmark (for me at least) is very faint, so at a glance, it may seem like its not checked but it is.
Is it editable for you?
There are multiple read only settings (badge group, type, etc.). Whole bunch of badges can’t be edited. Maybe it had stopped showing publicly between upgrades. I will need to dig in the code probably.
All read-only badges have an attribute “system = true” in the database.
No. Its greyed out hence not editable for me.
Yeah, as far as I know, the system badges can’t have a whole ton of editing done to them.
If you don’t want it visible to the public, the next best alternative would probably be to disable it fully, if that’s what your asking?
