I can play wack-a-mole by removing the plugin from the yml and then rebuilding but this is gonna take a while. I am wondering if there’s an easier way. I looked in the /logs but didn’t see anything good:
You can look in the Javascript inspector in your browser, it will usually give you the ID of the errant theme component (not sure about plugins). You can also look in the logs for rails errors and infer who to blame by the path of the files mentioned in the error.
