Come tradurre l'etichetta pubblicitaria di Google?
Hello
I added google add on a french website.
Where to modify label, to translate it in french ?
Nothing in params…
Many thanks
Not sure where that comes from, @neil?
There are quite some pull requests pending for that plugin, this is one of them:
https://github.com/discourse/discourse-adplugin/pull/51/files
It’s hard coded in.
https://github.com/discourse/discourse-adplugin/blob/master/assets/javascripts/discourse/templates/components/google-adsense.hbs
I guess it would be easy enough to have that be translatable. However, AFAIK, the terms are fairly explicit about what can be used as label text when a label is used.
Publishers have two options for how to label AdSense ad units: You can either label the units with “Advertisements” or “Sponsored Links”. No other variations are allowed at this time.
CSS temporary hack:
.discourse-adplugin .google-adsense-label>h2 {
    font-size: 0;
.discourse-adplugin .google-adsense-label>h2:after {
    content: "Foo bar"; // <--- change to whatever word you want to use instead of ADVERTISEMENT
    font-size: 12px;
Before:
After:
Might not cover everything.
Great !
Easy with css.
Many thanks !
It’s a bug that the string was hard-coded. I made a fix so it’s a translated string and will show in the site’s language (once translators have translated it). Also, you’ll be able to customize it in Admin like any string on the site.
