how to turn off posting cool down for 1st day users
my site just got like 40 members today and everyone is using the support email and asking to fix this ![]()
In a support thread titled ‘How to turn off posting cool down for 1st day users’, mason.menter seeks to disable posting restrictions for new users after a sudden influx of 40 members. Canapin advises adjusting ‘newuser max’ settings under admin settings — specifically ‘max topics in first day’ and ‘max replies in first day’ — and suggests setting the ‘default trust level’ to 1 to bypass cooldowns. However, mason.menter reports that new users still default to trust level 0 despite the setting. Canapin confirms they personally received trust level 1 upon registration, suggesting existing users must be promoted manually. mason.menter asks about running server commands to automate promotions, but Canapin clarifies this requires command-line access. Since mason.menter uses free.discourse.group, Canapin advises contacting Discourse support or manually promoting users if the count is low. The discussion highlights limitations for hosted Discourse instances and the need for manual intervention when automation isn’t available.
I’m still getting new users and they are all going to level 0 though I have it set as 1.
I’ve created an account on your forum and I’m trust level 1.
As for the previous existing users, you need to manually promote them.
I think there’s a command to do so, how can I find the way to execute commands on the site? I got to it before.
I think this message would be a good start:
https://meta.discourse.org/t/migrated-to-discourse-and-system-is-creating-hundreds-of-flagged-posts/93363/6?u=canapin
I just need to figure out where to put that?
In your server command line.
I don’t host my site, is there some way to find that in the panel?
No. Where is your site hosted?
Using free.discourse.group
Then you need to contact the support. If you have only a low number (a few dozens?) of users to promote to trust_level 1, you might as well do it manually.
