Continuing the discussion from Brand header theme component :
How can i access HTML codes of that bar? I can access CSS codes but i can’t see HTML code with Google Chrome’s “show source” feature. I want to use that bar on Wordpress side, o i need HTML template.
cmwebdev
(Colin Marshall)
08.Июль.2018 16:46:00
Just do a view source or use the Chrome inspector. The HTML code is generated in a script so it’s not something you will be able to copy paste from the component.
I get the HTML.
<header class="b-header clearfix"><div class="wrap"><div class="contents clearfix"><div class="title"><a href="http://www.example.com"><h2 id="brand-text-logo" class="text-logo">Site</h2></a></div><nav class="links"><ul class="nav nav-pills"><li><a class="widget-link" href="https://www.example.com" title="Link1"><span class="d-label">Link1</span></a></li></ul></nav><div class="panel clearfix"><ul class="icons clearfix"><li><a class="widget-link" href="https://twitter.com" title=""><i class="fa fa-twitter d-icon d-icon-twitter" aria-hidden="true"></i> <span class="d-label"></span></a></li></ul></div></div></div></header>
But how i compile SCSS? I tried compile that on Codepen but i think @import “theme_variables” line causes error.
@import "theme_variables";
.b-header {
width: 100%;
background-color: $tertiary;
height: 48px;
margin-bottom: 0; }
I want to create pure HTML CSS JS codes that component.
cmwebdev
(Colin Marshall)
09.Июль.2018 03:00:04
4
CodePen is fine. Delete that first line with the import.
Then, redclare all the variables at the top of the SCSS. You will get these values from Admin -> Customize -> Color Schemes.
If your secondary color is black, for example, you would declare it like this:
$secondary: #000000;
Put that at the top for every variable you see in that SCSS.
Hi,
I added that variables. Just, i can’t find $lightness variable in theme_variable.scss
$primary: #222222 !default;
$secondary: #ffffff !default;
$tertiary: #0088cc !default;
$quaternary: #e45735 !default;
$header_background: #ffffff !default;
$header_primary: #333333 !default;
$highlight: #ffff4d !default;
$danger: #e45735 !default;
$success: #009900 !default;
It does not work corretly yet. Can you check it?
Instead of using Discourse scss methods like dark-light-diff, scale-color and lightness you can just replace your desired colors directly in those places.
Thank you. @vinothkannans I added these variables. But i have problem HTML side i think.
I edited HTML side. There are some problems about styling.
<div class="wrap">
<div class="title">
<a href="#">
<h2 id="brand-text-logo" class="text-logo">Title</h2>
</a>
</div>
<!-- NAV -->
<nav class="links">
<li>
<a href="#" class="widget-link">
Link1
</span>
</a>
</li>
<!-- LINK 2 -->
<li>
Link2
</span>
</a>
</li>
</ul>
</nav>
<!-- RIGT SIDE -->
<li>
<a href="#" class="widget-link" title="">
<i class="fa fa-twitter d-icon d-icon-twitter" aria-hidden="true"></i><span class="d-label"></span>
</a>
</li>
<li>
<i class="fa fa-facebook d-icon d-icon-facebook" aria-hidden="true"></i> <span class="d-label"></span>
</a>
</li>
</ul>
</div>
<!-- RIGHT SIDE -->
</div>
</div>
</header>
cmwebdev
(Colin Marshall)
09.Июль.2018 15:09:40
9
@bekircem here’s a fork of your CodePen that’s almost all the way there. It just needs some work on the font.
I added the missing styles from nav.scss and also added a few CSS resets so the nav links would be properly positioned.
Thank you so much! I will check it when I moved my laptop for using hamburger menu should I add js codes?
cmwebdev
(Colin Marshall)
09.Июль.2018 16:01:39
11
No problem!
Yes, you will want to add some JS for the hamburger menu.
Can you provide JS side too?
cmwebdev
(Colin Marshall)
09.Июль.2018 16:04:59
13
I don’t think I can just copy the JS Discourse uses for that since it looks like it’s tied into their plugin system.
