Brand Header
:discourse2: Summary Brand Header adds an extra top header for branding with your logo, navigation links, and social icons for both mobile and desktop views. Brand logo can be an image or text.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-brand-header
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Desktop preview:
Mobile preview:
Settings
Name Description
brand name
website url
mobile logo url
links Text links to be displayed in the header
icons Icon links to be displayed in the header
custom font awesome icons List of FontAwesome 6 icons used in this theme component
show bar on mobile
plugin outlet
Using Font Awesome 6 Icons
To allow the Font Awesome 6 Icons to correctly display in this theme component, you will need to add them to 3 places in Discourse:
  1. The svg icon subset Site Setting
  2. The custom font awesome icons setting in the component
  3. The icons setting in the component
Additionally, for some Font Awesome 6 Icons, you will need to specify a fa or fab prefix with the icon name (Ex: “fab-bluesky”), due to some icons being part of a specific subset of icons. See We’re upgrading our icons to Font Awesome 6! for details about this usage.
Once you’ve added those icons in all three places, you should see them correctly displayed in the brand header theme component.
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
Is there a setting to add Facebook, twitter , Instagram profile links?
Beginner's guide to using Discourse Themes
Reuse Discourse Hamburger Functionality
Introducing Font Awesome 5 and SVG icons
How to use brand header html in my WordPress site
WordPress in a Discourse iFrame?
Login with federated social networks
Customise home login page
How to finely scroll out custom header?
How to put a backlink to our company website above the top-menu in discourse?
Can I add a icon and link back to my homesite at the top bar
How to create additional header?
Customize the header with links, icons, or menus
🌅 Introducing Horizon, our newest theme
Customize Your Site Branding
Dropdown links in existing Header
Need to create good-looking front page with Discourse login option
How I can add a custom header
Horizon interaction with Brand Header
How to add top menu bar like try.discourse.org
How to add a directory of people/businesses to my theme?
How to create custom theme component?
Custom website header with forum
Brand header theme component breaks page layout on static and no_ember pages
Adding header in theme messes up topic progress bar (when docked)
Structuring a multilingual community
Are these possible only with a custom theme?
Horizon Theme
How do I move an image/banner to the VERY top of the page?
TypeError: Discourse._registerPluginCode is not a function
DiscoTOC & Brand Header - using together
Brand Header breaks chat reply box on mobile (iOS)
Air Theme
Display name of forum
How to make your side have a side-bar and external links
TavoWEB theme for Discourse
Why does the logo navigate to Discourse home not main site home
Insert Link to External Website
Quick access to bookmarks and messages on user menu
Help needed with theming and logo
How do the Links and Icons settings work?
Customizing your site with existing theme components
How to embed Discourse in Wordpress?
@vinothkannans Great component!
One small issue. Currently, if a header link is internal to a site (e.g. to a particular category), if it is tapped in the responsive menu, the responsive menu will stay open. The expected behaviour is that the menu would close.
I am also seeing this issue for internal links, where the header does not disappear on mobile. Instead, the header slides right and leaves the main page opaque (I believe an overlay is being set), even if the header is folded back up.
Is there a fix for this?
In the mobile view, when we click on the hamburger menu, if then we click outside of the menu, the hamburger menu would be expanded even more, instead of closing. and also it has some other glitches. for example when hamburger menu is open and we click on a topic link.
I’m curious, is there some sort of code I can use/edit to move the links to this side of the header?
Ideally with the fa-icons left in place (on the far right). I’d just like to see what it looks like.
Hey there, would you be open to adding an option to display the bar below the header instead of above?
Sure, I will accept it if you can submit it in a PR.
Any hints as to what needs to be changed for that? I never worked with Discourse before.
https://github.com/discourse/discourse-brand-header/blob/master/common/header.html#L192-L194
You should mount the widget in “below-site-header” connector instead of “above-site-header”. It will require few more tweaks too.
Thanks, I got it to work! Will probably PR when I have a bit more time.
I merged your other PR which will add an optional target parameter to links.
https://github.com/discourse/discourse-brand-header/pull/4
This is now done in the commit below
https://github.com/discourse/discourse-brand-header/commit/9292116ca9734743f02a7730db3387b1074a5adb
I love this change, but on several sites where I use it personally, and on a hosted site I’m a moderator of (the NaNoWriMo forums) we’ve been seeing some issues. Unlike the regular hamburger menu, if you try to swipe it away it bounces back onto the screen.
I’ve personally seen this on a fully updated Moto (g7) Power on Android 9 and on a fully updated iPhone 8.
There has also been at least one report of the menu opening on touches near the icon and not just on it, but I’ve personally been unable to reproduce that particular behavior.
Thanks! Turns out I did not have time to make a proper PR, do you think you’ll be able to add the below/above site header setting?
Seems like it would be very useful to be able to add attributes to the header links somehow, e.g. for css class, target, etc.
I have had a query as to why the menu is not working on mobile devices. The user pressed on the left burger menu but then on a menu link - and his perception was it wasn’t working as the menu still filled most of the screen.
I’ve had to explain you need to touch somewhere on the right of the screen, to the side of the menu, to close it.
Would it be possible to make it more intuitive, either by:
  • Auto-closing the menu when you click on a menu link on mobile devices?
  • Including a ‘Close Menu’ button on mobile devices?
I’ve been meaning to make a similar request. I often try to dismiss the menu on mobile by swiping it to the left. It appears to be working, but then it pops back into place. The other menus in Discourse it works to swipe them back to the side to dismiss them.
Hello!
We experiment different layout between two version of the same forum (discourse 3.2.0.beta4-dev and discourse 3.3.0.beta1-dev).
Here is an example with no custom CSS, just the raw composant.
Does the discourse HTML layout changed between the 2 versions?
Also the “slide-in” behaviour is broken in the v3.3.
I’m having this same problem on Discourse 3.2.2. The slide-in behavior is broken.
I’m wondering, seeing on the dates of the above posts, is the brand-header theme component still supported?
Based on the previous 2 posts, it’s been broken for at least 5 months and no one has responded. I’m going to assume this theme component is dead unless someone says otherwise.
