I can't seem to get the licensed badge
Related to this:
… for the life of me, i’ve tried to get it… working through the introduction a few times… is there a command to manually kick this off?!
Did you finish the advanced user discobot narrative?
actually, it never kicked that off, which might be an issue…
This is a bit tricky to find. I would suggest to actually write the exact discobot command into those two badge descriptions. In order to get the licensed badge you just need to change the word new to advanced in the command line. So it reads: @ discobot start advanced user
Taking a closer look you can also find it in the discobot help section:
Well it is for advanced users, so… :wink:
oh, that :fire: … that BURN!
