Hi all,
I’m running Discourse 2026.2.0-latest (26f3e2aa87)
(Docker install, default nginx template, no Cloudflare). I have OpenID Connect enabled (Microsoft Entra / Azure AD).
When a user tries to sign up / log in via OIDC, Discourse records an error:
(oidc) Authentication failure! CSRFTokenVerifier::InvalidCSRFToken
In the log entry I can see the request is:
REQUEST_URI: /auth/oidcREQUEST_METHOD: POST- Referrer:
/signup
same_site_cookies is currently set to Lax.
My working theory is that the IdP is returning using response_mode=form_post (cross-site POST), so with SameSite=Lax the session cookie may not be included on the callback, causing Discourse’s CSRF verification to fail.
Questions:
- Is setting
same_site_cookies = Nonethe recommended / supported fix for OIDC providers that useform_postcallbacks? - If not, is there a recommended way to configure Discourse OIDC (or the IdP) so the callback is a GET (query) rather than
form_post, to avoid needingSameSite=None? - Are there any security/compatibility caveats with
SameSite=Nonespecifically for Discourse OIDC signups/logins?
Thanks!
