I need help on installing a plugin
A user, abstract, seeks help installing a ‘Who is Online’ plugin in Discourse, expressing confusion about the installation process abstract. Roi provides guidance, referencing the official guide and explaining how to add plugin URLs to the app.yml file, using the discourse-spoiler-alert plugin as an example. JammyDodger clarifies that the installation method depends on the hosting setup, noting that managed hosting may pre-install plugins, and directs to the Discourse plugins page for more information. abstract thanks the helpers and intends to try the process.
So, I am trying to install a who is online plugin but I have no idea how to.
The how to install thingy was kinda not understanding. Install plugins on a self-hosted site
I still didn’t get it ngl.
Well, you put the plugin url into the app.yml like shown in the link you posted:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-spoiler-alert.git
Here in the example, the plugin is discourse spoiler alert.
Ok so where would I put it? I’m honestly still confused. I just don’t understand.
It would depend on your hosting situation. If you self-host you can install all your plugins in your app.yml on your server (per the linked guide above).
But if you have managed hosting then the available plugins will depend on your hosting tier, and will generally come preinstalled. :+1: You can check out the available ones for our managed hosting tiers, for example, at https://discourse.org/plugins
Thanks Mate. I’ll go ahead and try it.
