Can you please just tell me how i can install a plugin step by step
i tried with this Install Plugins in Discourse but didn`t work.
Thanks
Thanks
Can you be more specific about what is going wrong?
I will yell you what am doing step by steep
i’m in my vps by SSH
i started with cd /var/discourse then ENTER
then i wrote this nano containers/app.yml and ENTER
am getting a very long menu, i dont now where i have to put this code
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
- git clone GitHub - discourse/docker_manager: Plugin for use with discourse docker image
- git clone GitHub - discourse/discourse-solved: Allow accepted answers on topics
because i want to install solved plugin
Please if you want to help me write it down step by step so i can make it. sorry am new on this.
Scroll down until you get to the first line “clone” in it, the docker_manager one.
type control-K to kill (cut) the docker manager line, then control-u twice to paste it back in twice. (Spacing is very important, so copying and editing a line that you know works is a good precaution).
Then, on the second line, delete the docker_manager URL and add the URL for the solved plugin.
Then control-X to exit and ./launcher rebuild app.
Sorry i did`t get it. @pfaffman
see the picture of what am getting.
You’ll need to scroll down using the arrow keys.
That`s all, you see the bottom of the page.
am trying to scroll more than this but this is the end of the page.
Sorry, yes i used the arrows.
i was trying the mouse… sorry again.
Ok i pasted, the docker manager is double one under the other… whats is next ?
Follow the above instructions, using only the arrow keys, not the mouse.
