Image upload issue
Hello,
I think this fix FIX: automatically timeout long running image magick commands (#12670) · discourse/discourse@5deda5e · GitHub is broke the multiple image upload. If i try to upload 3, ~5-6mb image it will not work, every time it shows this error. I think because of the 20sec timeout.
lib/discourse.rb:93:in 'exec': An error happened when converting from PNG to JPG.
Thank you :slight_smile:
Does this fail on this site? Can you try uploading the image (provided it is kids appropriate)
We need a limit here, we can not push it much beyond 20 seconds
Hi Sam,
Last time I tried it faild here too that is why I categorized it as bug but now it uploaded. On my site it every time fail. Size ~6mb / photo
Oh this is tricky, I want to debug locally. Can you upload one of the original images somewhere for me to download so I can test how long the various image magick commands take.
I can consider adding a “longer timeout” site setting, but I am somewhat concerned converting this simple image from png → jpg is taking upwards of 10 seconds.
Thank you! I uploaded some images to Mega 80.42 MB folder on MEGA
Can you confirm you are on a standard docker install.
I just tested one of your images above, we run 2 commands in the container.
and
timeout -k 40.0 20 convert jpeg:original.jpg -auto-orient -background white -interlace none -flatten -quality 90 jpg:/tmp/target.jpg
The first command takes 0.27 of the allotted 5 seconds on my local system.
The second command takes 1.3 seconds of the allotted 20 seconds.
Can you tell me a bit more about your install, and the particular performance of the server it is running on?
Thank you Sam, to checked this. Yes standard docker install. Yesterday I upgraded the server because so much slow down the whole website also… And did a rebuild. With the server upgrade it works fine. Just tested now. Digital Ocean has a new plan about 2 month with Premium Intel CPU and the other which we had the Regular getting much weaker.
The old server :arrow_down_small:
Basic - Shared CPU 2 vCPUs 4 GB 60 GB
The new server :arrow_down_small:
Basic - Premium Intel Shared CPU 2 vCPUs 4 GB 60 GB
Sorry for this topic. 20 seconds is enough. And thank you again! :slightly_smiling_face:
Yeah I think we are behaving correctly here.
If we do not timeout there is high risk that these under powered instances could get dominated by users uploading images. 20 seconds is a huge amount of CPU to give people for resizing images.
This topic was automatically closed after 15 hours. New replies are no longer allowed.
