Téléchargement d'image, chemin relatif au lieu de chemin complet
Hello,
When I upload an image on my Discourse, the image path is full not relative:
My question is, Is there any possibility to have the relative path /uploads/... instead of the full path ?
Unless you want to write a plugin for that, I’m pretty sure there’s no way to do that.
Why do you want these links to be relative?
We use a SSH tunel to connect to our discourse from outside.
ext (external.com) → int (example.com) but of course, all image are broken. With the relative path, there will be no problem.
In fact, why this is not relative path by default ?
That’s not a supported setup – Discourse needs to know the hostname it is running at. I’m pretty sure that there will be more breakage than just images if the hostname is wrong.
I you need outside access to Discourse, you’ll need to use a technique that allows you to access Discourse at the original domain name configured in app.yml, e.g. a VPN tunnel.
If you put the images on a CDN then your problem is gone :wink:
Damm simple. I juste add this in the config file:
DISCOURSE_CDN_URL: //externe.com:8883
And rebake all the post !
