Potential problem following a recent upgrade - Maybe Chrome related.
We’re seeing mixed content errors in the console and ImgFlip memes are not display correctly on Chrome with the latest Discourse and the latest version of the ImgFlip plugin.
Hi @cpradio, I can’t be certain when this started to fail as the community doesn’t use this plugin daily, but the first report coincided with me upgrading to a later version of 2.2.0.beta7 tonight.
We had previously been running an earlier version of 2.2.0beta7 but these errors surfaced after taking the +115 version. As I say, that might just be coincidental.
So far, it seems to only happen on Chrome - both mobile and desktop. Firefox and Safari both seem to work.
To reproduce
Simply post an image from imgflip.
In Chrome it will show a broken image icon
in the post and the console will display errors like this…
The MESSAGE_BUS_FAIL
errors only occurred after a polling delay - i.e. it looks like the page was made unstable before those errors occurred.
Some ‘odd’ stuff that might help you track it down
- The meme is actually created and displays in the preview pane prior to posting. Only once the Reply button is pressed does it fail to display properly in the post list.
- I get a notification from Chrome that ‘this page is trying to load scripts from unauthenticated sources’ that appears in the URL bar.
- Even though the meme in the post shows as a broken image link, the post depth observes the size that the embedded image would have taken up and if you mouse click the ‘space’ where the image should be, the lightbox appears and actually displays the meme.
- Oddly (to me anyway) If the meme was created in Firefox or Safari then everyone can see it, but if the meme was created in Chrome then nobody gets to see it.
Configuration details
The forum is hosted over https via Letsencrypt.
We’re running the latest version of your the plugin on Discourse v2.2.0.beta7 +115
I’ve reproduced it on Chrome version 71.0.3578.98 (Official Build) (64-bit) on Linux but it’s been reported as failing on Chrome mobile too.
