Import scripts fail to relate topics and posts
I’m writing an import script for a custom forum.
The importing of categories and users works good, but the script (using the create_posts method) is not able to build the relation between the topic and the replies.
The relevant code
//Topics
create_posts(threads, total: total) do |t|
  source_user_id = @usernamesMap[t["username"]]
    user_id: user_id_from_imported_user_id(source_user_id) || Discourse::SYSTEM_USER_ID,
    raw: t["Thread_Description"],
    created_at: t["created_at"],
    posts_count: t["count"],
    category: category_id_from_imported_category_id(t["Topic_ID"]),
    title: t["title"]
// Replies
create_posts(posts, total: total) do |t|
  next unless topic = topic_lookup_from_imported_post_id(t["Thread_ID"])
  opts = {
     raw: t["Post_Description"],
     title: t["title"],
     topic_id: topic_lookup_from_imported_post_id(t["Thread_ID"]), //This is not working correctly
     reply_to_post_number: topic_lookup_from_imported_post_id(t["Thread_ID"])
Any ideas?
The topic_lookup_from_imported_post_id() method returns a hash.
So, I’d rewrite your function to something like this:
  parent = topic_lookup_from_imported_post_id(t["Thread_ID"])
  next unless parent
  opts = {
     title: t["title"],
     topic_id: parent[:topic_id],
     reply_to_post_number: parent[:post_number]
Tratando de averiguar cómo crear un tema que pertenezca a un usuario específico en lugar del usuario administrador al ejecutar el script.
Por tu publicación parece que solo necesitas pasar el user_id a la API, aunque no está documentado, pero no parece funcionar para mí. ¿Es así y, de serlo, es user_id la columna id de la tabla users o la columna username?
