@funtent and @MJ94: The Blender community did a kickstarter to raise funds to pay for an import as well as significant improvements to the Vbulletin importer.
Perhaps one or both of your communities could do the same.
Luckily not The migration I am working on is a old clunky phpBB 3.0.X. Am currently analyzing which bbcode use cases I have in the data, how many of each, and doing some sample visual checks to see if any conversion issues remain. Btw, using this approach to find posts containing a specific bbcode as candidates for my checks (in mysql, for example):
Hi,
The import ended at least 6 hours ago. I looked at the sidekiq josb but I couldnāt find anything related to this. There was something like Category stats but it didnāt change anything after it was done.
If itās updated in a short future any way, thatās not a big deal. Thanks for your reply.
Yeah, I got it. In phpbb you could have categories in which you canāt post messages, they just act as parents for subcategories.
So there is no message in them.
The displayed number for a category only shows posts that are posted in this category but not those posted in a subcategory as you said. Seems weird though.
Another question since Iām here: what happens if I import my phpbb data twice? Does it skip already imported messages/users/passwords/attachments?
Still here. I noticed that my imported images arenāt displayed (404 error) though I imported them in the import settings.
Any idea how does that come from and if it is possible to fix the issue without having to re-import?
I also reorganized all my categories and moved messages to other categoriesā¦ Iād prefer not to do all of this again, I hope there is a solution.
edit: I discovered rake uploads:recover_from_tombstone. Hope that will help.
edit2: that helps.
That issue being solved, I have another question.
I imported from a fairly old phpbb dump ; December 2017. I did not notice until I made a lot of configuration and reorganization on my Discourse.
I can get a recent dump of my phpbb, what would be the proper way to add only the new (from December 2017 until now) messages, uploads and users to my Discourse?
I got that the importer will ignore the existing users categories and stuff but will it identify existing messages if I changed their categories on Discourse?
Also, on the last import I tried, I got the message after starting phpbb3_import.rb:
Table `phpbb.phpbb3_config` doesn't exist
I had my dump named phpbb_mysql.sql inside /var/discourse/shared/standalone/import/data and I edited settings.yml :
Iām not sure why it doesnāt find the phpbb3_config table. Thereās probably something wrong with your database dump.
The importer supports incremental imports. Simply put the new phpbb_mysql.sql and attachments into /var/discourse/shared/standalone/import/data restart the import. The importer uses the original IDs from phpBB3 to identify already imported data, so thereās no need to worry.
Anyway, itās probably a good idea to create a backup in Discourse before you start the next import. Just in caseā¦
Thanks for your reply. My dump seems fine but I do notice some differences between the two dumps.
Hereās a comparison of the first lines: https://www.diffchecker.com/ITAyzGCD (new one on left)
Thanks @Steven if I stop the discourse/app I can then enter import but of course the import fails because Discourse isnāt running. If I run docker ps -a this is what I see:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
0e44d0c41023 local_discourse/import "/sbin/boot" 24 minutes ago Exited (5) 17 minutes ago import
de1aa6a0e624 local_discourse/app "/sbin/boot" 24 hours ago Up 17 minutes 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp app`
So if I run docker stop de1aa6a0e624 I can then run /var/discourse/launcher enter import and it starts the import but as I said, of course fails.
Port 443 seems to be the issue, if I try to start the container [id] I posted above I see: Bind for 0.0.0.0:443 failed: port is already allocated
