I’ve been able to run the excellent import script for phpBB and get most of the content moved over with a few tweaks for our situation.
Thanks to @neil and everyone who had a hand in the script. I’ve made an addition to the script for placing the imported users into their respective groups also. I’ll add this to the official git and make a pr. Code at the end of message for review.
Has anyone had any luck with importing the phpBB3 group to forum permissions into Discourse as group to category permissions? I’m importing 123 forums so it’d be great if someone else had already knocked this out. I’ve searched meta but found nothing.
Importing user/group data:
def put_users_in_groups
# group_id 4 and 5 are taken care of in import_users
puts '', "adding users to groups"
progress_count = 0
total_count = mysql_query("SELECT count(*) count
FROM amazingc_forum.phpbb_user_group ug
join phpbb_groups g on g.group_id = ug.group_id
join phpbb_users u on u.user_id = ug.user_id
AND ug.group_id NOT IN (4,5);").first['count']
batches(BATCH_SIZE) do |offset|
results = mysql_query(
"SELECT u.user_id, g.group_id
order by user_id
LIMIT #{BATCH_SIZE}
OFFSET #{offset};")
break if results.size < 1
results.each do |users_group|
begin
current_user = find_user_by_import_id(users_group["user_id"])
current_group = group_id_from_imported_group_id(users_group["group_id"])
progress_count += 1
print_status(progress_count, total_count)
next if current_user.nil?
next if current_group.nil?
GroupUser.find_or_create_by(user: current_user, group_id: current_group)
rescue SystemCallError => err
puts "Couldnt add user to group: #{err.message}"
