Some questions on vbulletin import script (groups, likes, attachments)
I’m importing a community forum from vbulletin. And I can’t wait to get it done, because I want to start using discourse pronto.
I’ve managed to get the script running and it can import: users, groups, categories, topics (i.e. first posts) and then failed. Because I gave it only read access to my vb db (to be safe). The backup / restore feature is also invaluable in testing this stuff because it’s so easy to go back to an empty forum.
At this stage, before I run it again I have some questions on this:
  • How should I do the user ↔ group mappings? I see it takes the primary group in some way but I don’t see this on the imported forum anywhere. Plus other groups? I guess I’d be able to do the SQL from the mysql side, but how do I add the groups on discourse from the script? Thinking about it the easiest would be to do it “by hand” after import using bulk add user to group funciton.
  • Our forum uses the DragonByte Tech: Advanced Post Thanks / Like plugin. I guess I’d be able to figure out who liked/thanked which post from the MySQL database, but again, how do I import said like to discourse. Probably after posts have been imported I need to loop through all the likes/thanks in my database and like the corresponding post on discourse? (Can’t wait for the dislike button to disappear…).
  • I haven’t got to attachments yet, but our forum uses attachments that are stored in the DB it seems. Will this be handled by the script or do I need to make changes?
  • I see posts with vb code are not being formatted at present. I need to run something after import I believe?
Thanks!
You’ll need to create records in the post_actions table.
Here’s the columns you need to know:
id  serial primary key
post_id  integer fkey posts
user_id  integer fkey users
post_action_type_id  integer ; like = 2
deleted_at  timestamp null
created_at  timestamp
updated_at  timestamp
deleted_by_id  integer null, fkey users
I figured out a neat way to fix this. On the vb forum go to the attachment and switch storage to file based. It will ask for a folder and export all the attachments to that folder. When it is done, it will ask you to finalise this. At this point if you say no you have a folder with all the attachments but the forum is left untouched with attachments in the db.
I see the following remaining formatting issues on my transferred forum. That is after the post clean-up scripts ran:
Lists tags aren’t fixed
[LIST]
[*]item 1
[*]item 2
[*]item 3
[/LIST]
I guess I should just remove the tags and the brackets round the * and add a space and it should be formatted right. Any ideas how? I can update the import script regex I guess? Looking for some regex genius help.
COLOR tags
[COLOR=#212121][FONT=Helvetica Neue]blah blah[/FONT][/COLOR]
This seems to come from posts that were made on the old forum by posting formatted text into them.
I guess best would be to just remove the tags? Again need a regex expert I guess?
Is this a bug because this is BBCode? Should this not be picked up? I didn’t for example need to use backtick to quote the above.
Found a bug & PR on phpBB importer. This seems to also apply to vBulletin also.
https://github.com/discourse/discourse/pull/2927
I´ve updated the post_action table and imported our old likes. These are shown in queries, but not in the interface.
How do I refresh the interface?
Answer: rake user_actions:rebuild
Oh right, the importer should have been calling PostAction.act I think instead of inserting rows.
My bad!
Yes I wasn’t going to write the import code. Just did it manually from database to database. Then ran the rake. My ruby is bad.
رد متأخر جدًا هنا.. ولكني في نفس الوضع، هل يمكنك شرح كيف نقلت الإعجابات؟
