تركيب ميراث الخطاب - أحتاج إلى بعض المساعدة
So I took over a new position at a company, and we had been using Discourse - then moved to AnswerHub (:man_shrugging:) and I am probably going to move us back to Discourse.
I have used discourse before - but this install wasn’t really managed and no one knows what/how to access what’s currently running, and I need to get logged in and start Admin’ing it (it’s been set to Read Only).
I am trying to figure out where it’s being run on the box - I am not good with Docker but I have these instances:
   $ sudo docker images
   REPOSITORY            TAG                 IMAGE ID            CREATED             VIRTUAL SIZE
   local_discourse/app   latest              ---------------        11 months ago       2.366 GB
   discourse/discourse   1.3.10              ---------------        11 months ago       1.539 GB
   discourse/discourse   1.3.5               ---------------        18 months ago       1.501 GB
What’s the easiest way to get in here and get access to the Admin?
Edit: I was able to enter the docker image (app) so that’s a start
cd /var/discourse
./launcher enter app
rake admin:create
exit
And probably (to upgrade to latest, but you’ll probably need to upgrade Docker too)
cd /var/discourse
./launcher rebuild app
Awesome - will that walk through a process to create a whole new Admin?
The script is pretty flexible – it can create a new account for you, but if you give it the email address of an already existing user, it will grant that user admin privileges instead :slight_smile:
got it - excellent. Thanks @fefrei and @pfaffman
So after performing the above, I had to upgrade Docker on my server. With that done, everything came back up. However, I performed
And after waiting ~7min it failed with the following being the last bits of the readout:
FAILED
Pups::ExecError: cd /var/www/discourse && ln -s /shared/uploads public/uploads failed with return #<Process::Status: pid 3244 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "cmd"=>["mkdir -p public/forum", "cd public/forum && ln -s ../uploads && ln -s ../backups", "ln -s /shared/uploads public/uploads", "ln -s /shared/backups public/backups"]}
14a2deb1523549c18cc7c67e71ec4774f267df552dce399e61105dd3ef954dc0
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
@jerdog
Could you paste the output of these commands
df -hP (to check free space)
free -m (to check free memory)
uptime (to check load in the server)
i will as soon as a reboot works - after rebooting the server I’m not able to connect to it - it’s denying my ssh key - so working with my server team. :confused:
@jerdog
Feel free to PM me if they aren’t able to bring it back up.
I can help you if you need any assistance.
Alright so to update here… after a bunch of smaller issues, I finally got back to the server and have re-ran sudo ./launcher rebuild app and here’s the last few screens:
Start compiling CSS: 2017-12-21 16:43:51 UTC
Compiling css for default 2017-12-21 16:43:51 UTC
precompile target: desktop Default
precompile target: mobile Default
precompile target: desktop_rtl Default
precompile target: mobile_rtl Default
Done compiling CSS: 2017-12-21 16:43:55 UTC
I, [2017-12-21T16:43:55.601570 #13]  INFO -- : Purging temp files
Bundling assets
Compressing Javascript and Generating Source Maps
I, [2017-12-21T16:43:55.605198 #13]  INFO -- : File > /usr/local/bin/discourse  chmod: +x
I, [2017-12-21T16:43:55.608262 #13]  INFO -- : File > /usr/local/bin/rails  chmod: +x
I, [2017-12-21T16:43:55.611291 #13]  INFO -- : File > /usr/local/bin/rake  chmod: +x
I, [2017-12-21T16:43:55.614115 #13]  INFO -- : File > /etc/update-motd.d/10-web  chmod: +x
I, [2017-12-21T16:43:55.615837 #13]  INFO -- : File > /etc/logrotate.d/rails  chmod:
I, [2017-12-21T16:43:55.617538 #13]  INFO -- : File > /etc/logrotate.d/nginx  chmod:
I, [2017-12-21T16:43:55.620467 #13]  INFO -- : File > /etc/runit/1.d/00-ensure-links  chmod: +x
I, [2017-12-21T16:43:55.623444 #13]  INFO -- : File > /root/.bash_profile  chmod: 644
I, [2017-12-21T16:43:55.623611 #13]  INFO -- : > echo "Beginning of custom commands"
I, [2017-12-21T16:43:55.624942 #13]  INFO -- : Beginning of custom commands
I, [2017-12-21T16:43:55.625256 #13]  INFO -- : > cd /var/www/discourse && mkdir -p public/forum
I, [2017-12-21T16:43:55.627464 #13]  INFO -- :
I, [2017-12-21T16:43:55.627544 #13]  INFO -- : > cd /var/www/discourse && cd public/forum && ln -s ../uploads && ln -s ../backups
I, [2017-12-21T16:43:55.629935 #13]  INFO -- :
I, [2017-12-21T16:43:55.630007 #13]  INFO -- : > cd /var/www/discourse && ln -s /shared/uploads public/uploads
ln: failed to create symbolic link 'public/uploads/uploads': File exists
I, [2017-12-21T16:43:55.632215 #13]  INFO -- :
I, [2017-12-21T16:43:55.632491 #13]  INFO -- : Terminating async processes
I, [2017-12-21T16:43:55.632581 #13]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid: 43
I, [2017-12-21T16:43:55.632690 #13]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 156
2017-12-21 16:43:55.632 UTC [43] LOG:  received fast shutdown request
2017-12-21 16:43:55.632 UTC [43] LOG:  aborting any active transactions
2017-12-21 16:43:55.632 UTC [50] LOG:  autovacuum launcher shutting down
156:signal-handler (1513874635) Received SIGTERM scheduling shutdown...
2017-12-21 16:43:55.635 UTC [47] LOG:  shutting down
156:M 21 Dec 16:43:55.657 # User requested shutdown...
156:M 21 Dec 16:43:55.657 * Saving the final RDB snapshot before exiting.
2017-12-21 16:43:55.676 UTC [47] LOG:  database system is shut down
156:M 21 Dec 16:43:55.884 * DB saved on disk
156:M 21 Dec 16:43:55.884 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && ln -s /shared/uploads public/uploads failed with return #<Process::Status: pid 3256 exit 1>
4b44820ca7a1600d0687192790f721fb36267d7e8529b1a0107b9a0df2977b56
any guidance here?
edit: looks like it’s failing here first on the custom commands:
and then everything shuts down… what already exists is this:
lrwxrwxrwx 1 discourse root 15 Dec 21 14:27 uploads -> /shared/uploads
This is the problem:
Looks like you are dealing with a subfolder install.
Check our guide Serve Discourse from a subfolder (path prefix) instead of a subdomain and amend your yml file on the containers folder to follow it.
Yeah just added to my thoughts above… let me have a peruse of that link
We were already setup for folders correctly - it was actually due to creating symbolic links which already existed - so it failed. Now we’re back up… however, login is disabled due to being in read only mode. Any way to change this manually so I can login?
Edit: found this How can Admin login while Read-only mode is enabled on multisite? and am checking it out
Ran discourse disable_readonly and got the “The site is now fully operable.” message, but when I reload the browser it doesn’t let me login, saying it’s still in readonly mode. I performed a ./launcher reload app and it is still in readonly mode
Tried:
rails c
Discourse.disable_readonly_mode
And it returned
=> true
No dice.
Tried:
rails c
Discourse.readonly_mode?
And it returned
=> true
Seems like it is locked in RO mode?
I went ahead and replied in here (Stuck in 'Read Only' Mode - #10 by tgxworld) as what I am experiencing now is more in line with that topic
There are 3 different types of read only.
Try:
rails c
Discourse.disable_readonly_mode(Discourse::USER_READONLY_MODE_KEY)
Discourse.disable_readonly_mode(Discourse::READONLY_MODE_KEY)
Discourse.disable_readonly_mode(Discourse::PG_READONLY_MODE_KEY)
yeah I ran all 3 of those - and it stays out of read only mode (or at least doesn’t have the note at the top about being in read only mode), when I try to login it does this and stays there:
Looks like you have 0 enabled login methods :smile:.
Go to /u/admin-login to login.
Thanks for all your help. Looks like I am back in. Assuming I can just make it read only while still being able to login as Admin via that link above
