Installing problem - bundle install
Good morning,
Using bundle install, the installation is infinitely struck at kgio 2.10.0.
Can some one help me?
Thanks.
For live production server recommended installation method is Docker.
For local development environment recommended methods are Mac OS X, Ubuntu and Vagrant guides.
All other installations are officially not supported and difficult methods also.
I guess you are not using one of the recommended methods above.
For bundle install, should the databases be populated and script running important?
Thanks.
So you are installing for development environment. You chosen #meta category for this topic that’s why I confused (now I changed it to Development).
Yes. It is important.
thanks vinoth. I am trying on it.
The problem still persists even after following up with the guide.
