shoshber
(Shoshana Berleant)
1 Marzo 2018, 10:38pm
1
Problems I’ve run into so far:
Brewfile is broken (Brewfile is out-of-date? )
apple-gcc42 doesn’t work past Mavericks
It forces an installation and use of ruby 2.0.0, but rails requires version >= 2.2.2 (this is in the output: ERROR: Error installing rails: activesupport requires Ruby version >= 2.2.2.)
It requires bundle to be installed but doesn’t install it (or mention it in the documentation)
I was following instructions here: https://github.com/discourse/discourse/blob/master/docs/DEVELOPMENT-OSX-NATIVE.md
And as a side note, I still haven’t managed to install discourse.
I think @j.jaffeux looked at this recently?
j.jaffeux
(Joffrey Jaffeux)
3 Marzo 2018, 11:56am
9
Hi @shoshber I will update the guide in the future. No ETA yet.
sam
(Sam Saffron)
17 Maggio 2019, 1:55am
10
Sorry it has take us so long, most of us are simply not using the quick setup so I have removed it.
I think it is kind of fair to require a “long setup” from people on osx cause so much personal taste is at play.
For ultra quick setups we have:
Developing using Docker
Since Discourse runs in Docker, you should be able to run Discourse directly from your source directory using a Discourse development container.
Pros: No need to install any system dependencies, no configuration needed at all for setting up a development environment quickly.
Cons: Will be slightly slower than the native dev environment on Ubuntu, and much slower than a native install on MacOS.
See also Developing Discourse using a Dev Container …
