Instance broken cannot load such file simple-rss
I did add a new plugin and got automatic the last version.
./launcher cleanup
./launcher rebuild app
end in this error:
LoadError: cannot load such file -- simple-rss
Here is the full log:
I, [2017-12-09T10:07:24.953141 #13]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in `require'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:258:in `load_dependency'
/var/www/discourse/plugins/discourse-autobot/app/jobs/regular/poll_website_feed.rb:5:in `<class:PollWebsiteFeed>'
/var/www/discourse/plugins/discourse-autobot/app/jobs/regular/poll_website_feed.rb:4:in `<module:Jobs>'
/var/www/discourse/plugins/discourse-autobot/app/jobs/regular/poll_website_feed.rb:3:in `<top (required)>'
/var/www/discourse/plugins/discourse-autobot/app/jobs/base.rb:26:in `require_relative'
/var/www/discourse/plugins/discourse-autobot/app/jobs/base.rb:26:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:286:in `load'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:286:in `block in load'
/var/www/discourse/plugins/discourse-autobot/plugin.rb:25:in `block (2 levels) in activate!'
/var/www/discourse/plugins/discourse-autobot/plugin.rb:25:in `each'
/var/www/discourse/plugins/discourse-autobot/plugin.rb:25:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:270:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:268:in `each'
/var/www/discourse/lib/plugin/instance.rb:268:in `notify_after_initialize'
/var/www/discourse/config/application.rb:219:in `each'
/var/www/discourse/config/application.rb:219:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/lazy_load_hooks.rb:67:in `block in execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/lazy_load_hooks.rb:60:in `with_execution_control'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/lazy_load_hooks.rb:65:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/lazy_load_hooks.rb:50:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/lazy_load_hooks.rb:49:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/lazy_load_hooks.rb:49:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application/finisher.rb:73:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:30:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:30:in `run'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:59:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/initializable.rb:58:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application.rb:353:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing'
/var/www/discourse/config/environment.rb:5:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application.rb:329:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/application.rb:445:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rake-12.1.0/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => db:migrate => environment
I, [2017-12-09T10:07:43.575814 #13]  INFO -- : gem install yt-support -v 0.1.3 -i /var/www/discourse/plugins/discourse-autobot/gems/2.4.2 --no-document --ignore-dependencies
Successfully installed yt-support-0.1.3
1 gem installed
gem install yt -v 0.32.1 -i /var/www/discourse/plugins/discourse-autobot/gems/2.4.2 --no-document --ignore-dependencies
Successfully installed yt-0.32.1
1 gem installed
I, [2017-12-09T10:07:43.576606 #13]  INFO -- : Terminating async processes
I, [2017-12-09T10:07:43.576706 #13]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid: 42
I, [2017-12-09T10:07:43.576862 #13]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 155
2017-12-09 10:07:43.577 UTC [42] LOG:  received fast shutdown request
2017-12-09 10:07:43.577 UTC [42] LOG:  aborting any active transactions
2017-12-09 10:07:43.579 UTC [49] LOG:  autovacuum launcher shutting down
2017-12-09 10:07:43.581 UTC [46] LOG:  shutting down
155:signal-handler (1512814063) Received SIGTERM scheduling shutdown...
2017-12-09 10:07:43.608 UTC [46] LOG:  database system is shut down
155:M 09 Dec 10:07:43.609 # User requested shutdown...
155:M 09 Dec 10:07:43.610 * Saving the final RDB snapshot before exiting.
155:M 09 Dec 10:07:43.646 * DB saved on disk
155:M 09 Dec 10:07:43.646 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 395 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
a7f1896ead97d3d5a82d2229b56a75354c7972bc6a6cd889f83d4fc091f7ec62
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Do you have the Autobot plugin installed?
That plugin is now officially broken. Read the topics there.
Removing the plugin fixed it, thank you!
