Integration: Discourse comments in Gitbook
The discussion revolves around integrating Discourse comments into GitBook using JavaScript, similar to implementations in Ghost. amonle seeks a solution to embed comments per page in GitBook, referencing a past attempt and GitBook’s beta API. Ahmed_Gagan expresses interest and initiates contact via PM. amonle thanks Ahmed and confirms communication. Later, amonle announces a pause in the project as they evaluate alternative options.
What would you like done?
I would like to embed comments in GitBook similar to what is possible in Ghost and elsewhere using javascript - the idea being that the comments would embed per page in Gitbook. You may already know that Gitbook is no longer open source but they do have a beta API. Naturally I accept the risk of the API’s beta status. If it helps, there were some tries at this in the ‘old days’.
When do you need it done?
April tbc
What is your budget, in $ USD that you can offer for this task?
I haven’t done this before. Let’s discuss.
Hi John,
I am interested to take this up, sending you a PM.
Thanks Ahmed. I have messaged back
All, putting a hold on this as I may not proceed with Gitbook. Evaluating options.
