Ipad mini with IOs 6.02 display but won't link to single Suggested Topics
Hello there,
i have a user with Ipad mini IOs 6.02 and its Safari. If she tip on a topic inside the Suggested Topics it won’t load the topic. In our Office we habe an bigger and newer Ipad with IOs 8.x and its Safari. On this is works fine.
My Discource version is v1.4.0.beta3 +3 .The server runs on normal Ubuntu 14.04 at Digital Ocean → http://diskutierbar.com
Do you have a hint to fix it with the older Ipad Mini?
Thanks for your great piece of Software :ok_hand:
Can this Mini be updated to a newer version of iOS?
The owner said no. This was also my first question and i think this could be the resolution.
That does not make sense. No shipped iPad Mini is limited to iOS 6, here is the wikipedia entry for the 1st gen iPad Mini:
Even the old iPhone 4, from 2010, can be updated to iOS 7…
On September 17, 2014, iOS 8 was released to the first generation iPad Mini and all Apple Devices
I think she won’t. But I will try to convice her. Thanks for your research.
It looks like we are no longer fully compatible with iOS 6 unfortunately, so I will update our minimum spec to be iOS 7
Note that iOS 7 is supported on a lot of Apple devices, as far back as iPhone 4 from 2010..
I’ve convinced her and together we upgraded her iPad mini to 8.4 and it works well.
Thanks :smile:
