Wordt het wijzigen van het thema op meta opgeslagen als een gebruikersinstelling of op basis van cookies?
I often have to rechange my default theme from the drop menu
Unavngivet
  • is the setting cookie based and not profile stored?
Or why do I have to change the theme when I login?
I think swapping from the sidebar is just for that session, the setting at https://meta.discourse.org/my/preferences/interface is across all sessions, if you select the “Make this the default theme on all my devices” checkbox.
Yes, it’s session based. The component utilizes setLocalTheme(); which is the equivalent of changing this interface setting with the “default on all devices” box unchecked.
Screenshot 2024-01-16 at 10.56.29 AM
This way the same functionality works for both logged-in and anonymous visitors.
I think I can include makeThemeDefault when logged in, so it persists along with the account.
