Hi,
I am using category view as homepage. Is it possible to add posters section latest topics on category view?
Thanks.
No that is not possible out of the box. You will need to write a plugin for it.
Hi, thanks for the reply. Writing a script on the front end or a plugin that works on the backend?
A plugin, so backend. The endpoint for that route doesn’t contain the list of users in the topic, so you need to add that and then use it on the front-end.
