<object>を埋め込んで表示することは可能ですか?
Hello friends,
I am woundering if I could be somehow embed the following code and show the image:
<object type="image/svg+xml" data="https://o.smium.org/api/convert/7899/svg/7899-pvp-vexor.svg"><a href="https://o.smium.org/loadout/7899">View PVP Vexor on Osmium</a></object>
I am planning a section with discussion about those inGame ship fittings, and it would be beautiful if they could be directly embedded without any hustle of work.
Thanks for help,
Daniel
This is not trivial but you could make a custom onebox that lets this through. This would require authoring a plugin. Have a look at the onebox repo at GitHub for examples.
Thanks a lot for the tip. I still have to learn a lot, so after some learning progress I will have a look if I am able to do it :slight_smile:
