是否可能嵌入并显示 SVG 图像?
I am woundering if I could be somehow embed the following code and show the image inside a Discourse Post
Did you mean to include some code in your post? If you can give us a description of what you are trying to do, we may be able to help.
2 个赞
yess can i use
<object type="image/svg+xml"
inside post ?
Why would you do that instead of uploading a .svg image file in the same way you’d upload a .png or .jpg file?
1 个赞
