Is het mogelijk om een link naar "Latest" in de zijbalk in te schakelen?
I don’t like how “Latest” is no longer in the sidebar though. Any way to simply add that under “Community”?
Hi STORMS ! :cloud_with_lightning:
You can change the behavior of the links in the sidebar in your user preferences:
It’s not exactly the same thing, but maybe that could suit you :slight_smile:
edit: I might have misread you. Clicking on “Everything”, by default, leads to /latest.
Love the storm cloud!
Thanks for the suggestion, but that’s not exactly it. I feel the sidebar handcuffs me in a way now. When clicking on your avatar in the upper right; it should still be able to link you like normal, but it doesn’t and that bothers me too.
OK edit on the avatar thing, but the latest link is still a problem for me and I feel if it bothers me, it will probably bother others too.
