האם יש דרך קלה לראות אילו קטגוריות קיבלו הכי הרבה צפיות?
סיכום מבוסס בינה מלאכותית
The discussion revolves around finding an easy way to determine which categories have the most views, specifically for the desktop category page style “Boxes with Featured Topics”. Tris20 wants to order categories roughly based on their total views, but also wants the flexibility to manually spotlight less viewed categories. JammyDodger suggests using the topic_views table to grab a count of the latest views for a topic, grouped and summed by category. However, Tris20 later discovers a more useful query, “Number of replies by Category”, which can be repurposed to find views by category. This query can be accessed by appending /admin/plugins/explorer?id=-18&params=%7B%7D to the domain.
This question is mostly considering the desktop category page style Boxes with Featured Topics
The problem is as follows: I have roughly 20 categories, and want to order them roughly based on how many views the category gets. So if Category A has had the most total views, then it is in position 1. If Category B has had the second most total views, then I can put it into position 2 and so on. However, from time to time I want to spotlight a category which does not have many views by manually putting them in the 3rd or 4th slot.
I suspect this might be possible with a data explorer query, but it might be non-trivial. Is there already an easy way of achieving this information? Maybe there is existing information in some of the reports I could re-purpose?
I think you could use the topic_views table to grab a count of the latest views for a topic, and group/sum that by category? The topic_views table counts one new view a day though, rather than ‘1-per-8-hours’ so it may give a smaller figure than you may be expecting when compared to the topics.views number.
Thanks for the suggestion :slight_smile: I’ll give it a go next time I’m working on this topic
Whilst working on a different Data Explorer query, I found something which provides information I think might be more useful. There is a query which ships with core called “Number of replies by Category”
Assuming the ID is the same for every site, then appending this to your domain should provide the same query
If someone was looking specifically for the views only, then I’m sure they could re-purpose that query. Essentially combine the suggestion from Jammy with this one and you get the result.
