Is er een ongedaan maken van "remote afbeeldingen downloaden naar lokaal"?
The discussion revolves around reverting the download remote images to local feature in Discourse. Brandon007 asks if it’s possible to undo the download of remote images, as they want to revert onebox images to their original source links after disabling the feature. pfaffman explains that the process is not straightforward because the image URLs are replaced with local upload markdown, and the only way to revert is to restore the original post revisions before the images were downloaded. They suggest using a database query to find affected posts and manually revert them, though no specific code is provided. Brandon007 appreciates the explanation with a lighthearted tone.
Is it possible to revert the download remote images to local option?
I turned it off, but I have lots of posts where I dropped a news link in a post, and the remote image was downloaded to my forum, as expected. However, perhaps this is a bad strategy looking long term. Most news we forget about the next day, so why keep the images long term?..
Anyway, I turned off the feature, then rake posts:rebake hoping the onebox images would revert to the source link. No dice. The onebox images are still using the downloaded image from the forum instead of the source link.
Is there a way to make the forum forget about the previously downloaded images? I would have thought a rebake would cause the onebox to use the source image.
Not easily.. The URL of the images are replaced by the upload markdown for the local image. You would need to revert to the version before the URL was replace by the image, and then after a while, Discourse will delete the images that are no longer referenced in a post.
Most sites really don’t want broken images, so the download option is what most peoplel use.
You can find those with
PostRevision.where("modifications like '%downloaded local copies of images%'")
Writing code to revert all of those posts is left as an exercise for the reader. :slight_smile:
It should be just a couple of lines of code, but I don’t know what they are without looking at the code.
If the reader even wants to attempt such an endeavor! :grinning_face_with_smiling_eyes:
Thanks Mr. Jay!
